daytime running light problem - Nissan Forum
post #1 of 13 Old Mar 24th, 2004, 11:26 AM Thread Starter
My 93 Maxima's Daytime Running Light (DRL) started having problem a few months ago. When I am driving during the day, the DRL keeps turning on and off automatically. There is no way to control it. Does anyone know how to fix it or disable the DRL?
stephenho56 is offline
post #2 of 13 Old Mar 25th, 2004, 09:06 PM
Hates everyone.
Felonious Cat Stalker's Avatar
If the maxima is anything like the Sentras, there should be a fusible link box under the hood. Find the one with DRL on it and try to take it out and see if that helps.
Originally Posted by Myidolis
You're grammar sucks.
Felonious Cat Stalker is offline
post #3 of 13 Old Mar 28th, 2004, 03:36 PM
drl problem
try switching your relay with another one
if that doesnt help try playing with either your neutrasl switch or your handbrake switch.
if it doesnt improve try cleaning your ground connection if it still doing it find a drl module from afriend or a scrap yard if it still doesnt work well ,sell the car .....
Spankeesr20det is offline
post #4 of 13 Old Apr 17th, 2004, 10:45 AM
the drl module is located under the steering column under the large panel. They usually fail when a cracked solder joint occurs, causing the drl's to come on and off. The module is attached with two screws and has two plugs. If you open the module and scan the board you'll see at least one solder joint has a circular crack around it. They crack at the connection for the relay (large winding of copper).Use electronic solder and a small soldering iron.
B.Somers is offline
post #5 of 13 Old May 6th, 2004, 12:37 PM
rcy
Had a similar problem with my '92. I replaced the DRL module and the problem continued. Believe it or not, it was the headlight switch causing the problem. A new switch (it's actually the entire turn signal stalk) is about $70 CDN at the stealership. Oddly enough, the stealership had one in stock, as it's a known weakness with the switch.
rcy is offline
post #6 of 13 Old May 9th, 2004, 01:34 AM
Hmmm...wonder if that's my problem, too. What my car will do is run with the DRL's, and then all of a sudden have only 1 high beam going on at maximum power, and then go back to normal. Probably my switch, too.
I can picture it...I'll be behind a group of Hell's Angels, and then it'll happen...
___
John
taurus8 is offline
post #7 of 13 Old May 11th, 2004, 10:41 PM
Nissan Fanatic
any idea how do dissconnect the D.T.R so they don't come on at all? Just want my fog light's to come on it's a 94 sentra.
new94 is offline
post #8 of 13 Old May 15th, 2004, 04:22 PM
Nissan Fanatic
same problem with my sentra, except ive pinpointed it to the drl module right on the firewall.. if it doesnt work, i just lightly tap it and it decides that it watns to work? eh well, im just going to have to crack it open and re-do theconncetions if they're cracked.
1992 Nissan Sentra Classic 5spd
muccman is offline
post #9 of 13 Old May 22nd, 2004, 03:23 PM
Marcus's Avatar
I know that this is the wrong section but I am having trouble with my 1995 Nissan Pickup headlights. When I drive there is only one headlight working (left) in DRL mode . When I turn on the park lights still only one headlight. When I turn to low beam it still won't work but if I tap the right headlight slightly it will come on, however as I drive it flickers on and off (really dangerous for night driving). The only time the headlights work is if I use high beams. I went to my dealer and they said that it was most likely the DRL module ($115 cdn). I have phoned about 5 scrap yards looking for the part but no one seems to have it. Can anyone guide me to fix the problem. I have cleaned and checked all the contacts as well as replacing the headlight.
Can someone help me?
Marcus
Marcus is offline
post #10 of 13 Old May 22nd, 2004, 08:58 PM
Nissan Fanatic
Are you sure it's not just a bad bulb or connection to the bulb? My headlight was doing sorta the same thing and when i wiggled the connector it would work, so i replaced it and it's been fine ever since.
new94 is offline
post #11 of 13 Old May 23rd, 2004, 08:06 PM
Marcus's Avatar
Should I replace the headlight connection?
Marcus is offline
post #12 of 13 Old May 23rd, 2004, 08:19 PM
Nissan Fanatic
It's cheap just to go to the wrecker's and grab one, if it work's great it wasn't too expensive if it does'nt then go to the nest possible cause. Just turn the light's on and wiggle the connection's first though, that'll at least give you an idea if they malfunction then you know that's what it is!
new94 is offline
post #13 of 13 Old Aug 30th, 2004, 11:32 PM
DRL module or Something else also
I have only the driver's-side running lights working. The low-beams work when they feel like it--sometimes one or the other, sometimes both, sometimes none. The stealership tells me it's the drl module and they want $175 + tax. Told them I'd get out the duct tape and fix it myself. Having read all the posts, I suspect it's the little box on the driver side firewall. Do I have to cut/break the plastic box to get at the module (assuming it's in there)? Suggestions, please
granny is offline
  Nissan Forum > General > Regional > Canada & International
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Linear Mode Linear Mode
Tiny (?) electrical problem - 92 SE-R RED92SE-R B13 91-94 chassis 10 May 17th, 2004 01:38 PM
'01 Pathfinder Shimmy problem. EvilMonkey Truck & SUV 5 Mar 5th, 2004 02:28 PM
Red light on SE-R Badges Wiseco Cosmetic Mods 12 Jan 25th, 2004 04:08 PM
problem with alpine amp, need help ahardb0dy Audio 6 Jan 1st, 2004 02:06 PM
having trouble with my engine check light palengkeboy S13 240SX 1989-1994 4 Feb 5th, 2003 04:39 PM
You may post new threads
You may post replies
BB code is On
