Originally Posted by Flying V
oil does not give you a HP increase. Oil and HP are non-corrolated as far as cars are concerned. and an CAI will net you maybe 3-5hp at the crank at sea level, and even less at higher altitudes. HP= more fuel consumed. thats why a 500hp V8 consumes more fuel than a 150 hp 4 cylinder. You should slap who ever told you this, becuase they were leading you on hardcore
ok, so there's an arguement about oil! first of all, take in the acount of how thick an oil is going to be! example, wave your hands around in the air, then wave your hands around in the water. . . which ones harder ? obviously water, but this is the same with oils, some are thicker than others.
so if you have a thinner oil in your car, then all the moving parts that incounter that oil, are going to move easier and less stressfully: therefore less horsepower robbing!
go ahead and drop the thickess oil you can find into your car, and you'll feel how much horsepower is being robbed from a thick oil
and the comparison btwn a 500hp and 150hp car's gas mileage ?
i mean, that's obvious, but don't push your luck! i've seen big ponys push lots of miles compared to smaller engines.
and look at it this way. . .
if you gain 5 hp to the wheels due to some kind of tech devise, then this means that the engine is working more on moving your car forward, than actually moving it's internals. . . so this doesn't mean it's taking more fuel!
say you have 150whp, and now 155whp due to thinner oil with less friction. . .. well your engine is putting out the same amount of work but now it is taking that 5 hp it took to move thicker oil and through friction, and is now applying that 5hp to the wheels. so it's gunna be easier for the car to move
therefore, the car moves faster with the same amount of power, technically.
and with same gas usage,and time, more distance covered faster, this means a better gas milage! now i'm not talking serious significants in gas saving, but i'm giving you an idea about what this means
there was a commercial out with an example like this. . . i think it was a Quaker oil commercial with a STi as it's car---- 'you paid for 300 horses, but are you getting all of them?' as i remember
just pay attention to that and maybe you'll understand
p.s. more horsepower doesn NOT always mean more fuel consumed
have a good one
