Drained my oil and went to take the old filter off. Hmm my filter wrench (kind that goes on my socket) doesn't fit it. Start looking around for my regular adjustable filter wrench and can't find it. This is what happens to me when that one time I'm in a rush I take it to a quick lube place instead of doing it myself.
It's 9pm and I have to work tomorrow morning. So I replaced the drain plug and filled the car up with new oil. The current filter has 5k miles on it (yes I know I was way overdue changing the oil). So should I go buy a adjustable filter wrench tomorrow and change the filter (and oil again) or just leave it for another 3750 miles (so 8750 miles total on the filter) until I change it again?
Any thoughts are appreciated.
I guess you could leave it, but it probably wouldnt be a good idea. Probably could go for a day or two. But you should change it ASAP!
every 3 months or 3,000 miles change OIL
every 6 months or 6,000 miles change OIL FILTER
so you could ideally just wait until you next oil change, but since its so old already i dunno. i would change the filter for good measure, but you dont need to change your oil again.
oh yeah, as far as a filter wrench goes. i dont use them, instead i use my rubber coated cotton gloves. i wear gloves when i do most anything car related cus im sick of getting cut up (rust=tetnis? ouch), and it just makes sense to use them for oil filters. the rubber gives adequate grip to remove the filter.
I'll edit YOUR signiture!
Really? I can't picture myself ever getting the filter off with just gloves, but I guess I've never really tried rubber gloves before.
medalian1, changuing the filter ASAP is probably the best idea ... but these things are generally over-engineered for what we (car guys) use them for. They are designed with the average-idiot motorist in mind and can swallow a lot more gunk than we think. So, if you left it on for 2,000 miles or more then changed your oil again, that'd be OK too.
When an end-cap wrench is a bit too loose, you can place a spread-out rag over the filter, then put the wrench on again and that will often take up enough slack to allow the larger wrench to get a good "bite."
And yes, I can often get oil filters off with my bare hand ... as long as I was the one who put it on.
Some mechanics, eager to prove their hairy-chested manliness, torque these things down until their knuckles bleed ... then wonder why they have a hard time getting 'em off.
"Old school mechanic trick is to drive a screw driver right through the mother, then twist it off using the leverage from the screwdriver."
Yes, but you would only resort to that if you crushed the canister some trying a different type of wrench. You should never do this to a perfectly intact filter.
Christ on the 2000+ Sentra??? You might be able to pull it off on the Spec V SE-R model (I dunno where the oil filter is located in THAT one) but in the 1.8 that I have forget it. You'll NEVER get the power to pound the screwdriver through the filter best to just get gloves and get it by hand (I always take 'em off and put 'em on w/o gloves )
ya i had the same problem when i tried to change teh oil filter myself.......i ended up just going to the dealer to get the oil filter change with the new oil i had just put in.....ugh i spent like 30 bucks trying to buy the right oil filter wrench.....none of them worked
