Go Back   NissanForums.com :: Nissan Forum > Nissan Models > Sentra, Pulsar, NX, B14 200SX > B15 2000-2006
B15 2000-2006 2000+ Sentra including 2002+ SE-R and SpecV
Old Oct 5th, 2004, 08:04 AM   #1 (permalink)
02 QR25
02 QR25's Avatar
HELP WITH THE FUEL PUMP
i was wandering if anyone could help me out with a problem, i have a 02 spec v and i thought the fuel pump was getting weak with me , because it will crank like a champ when it is cold, but when it gets good and warmed up, i'll try and crank it and it will try to fire like it is going to crank then it goes dead instantly, so i ordered a new fuel pump and put it in and, its doing the same thing, im thinking it may be a relay or something but i have no clue which relay it is, if anyone could help out with the relay location or any ideas what they think it may be....................
02 QR25 is offline   Reply With Quote
Old Oct 5th, 2004, 08:35 AM   #2 (permalink)
xxMIKExx
xxMIKExx's Avatar
Send a message via AIM to xxMIKExx
The fuel in your fuel rail is evaporating when the car is hot. All you need to do to fix it is when the engine is hot and you want to start it again, just get in and turn the key to the "ON" position but do not start the car. You'll hear the fuel pump prime and shut off. Once it does that just turn the key all the way over and start the car. I had this problem for a long time and I read to do this. Now it's just another thing I do to get my car started during the day. Just another joy of owning an 02 Spec V. This may not be what you wanted to hear but it's a free fix and it has worked for a lot of people.
'02 Sentra SE R Spec V, i/h/e, Progress springs, TSW rims, Goodyear Eagle F1's, CF Hood, CF dash kit(SOLD)
'05 Dogde SRT-4 (New BOOST)
xxMIKExx is offline   Reply With Quote
Old Oct 5th, 2004, 05:00 PM   #3 (permalink)
02 QR25
02 QR25's Avatar
i do this and it still just keeps turning over, ill wait til the fuel pump prime quitss then try to start and nothing happens? i cant figure out whats wrong with it
Old Oct 5th, 2004, 05:03 PM   #4 (permalink)
02 QR25
02 QR25's Avatar
and it just started doing it within the past few weeks, im affraid if i keep driving it is going to screw up bad on me while im off somewhere
Old Oct 5th, 2004, 05:17 PM   #5 (permalink)
caveman
Nissan Fanatic
Has the ECU recall been done? If you've replaced the fuel pump and you still have the problem, then it probably isn't the fuel pump.
You need air, fuel, spark, timming (ECU) and compression for your car to start. How many miles do you have on the car?
caveman is offline   Reply With Quote
Old Oct 5th, 2004, 05:21 PM   #6 (permalink)
02 QR25
02 QR25's Avatar
48k
Old Oct 5th, 2004, 06:56 PM   #7 (permalink)
caveman
Nissan Fanatic
48k
Geez, kinda early for starting problems. Are the spark plugs original? How does it run once it's started?
Check your oil level. The cars come with a 7 year 72K powertrain warranty.
How to replace a 93 nissan nx 1600 fuel pump cesemj GA16DE 1.6L Engine 3 Sep 25th, 2004 11:33 PM
87 Sentra Fuel Pump Glacophane E/CA-Series & GA16i Engines 8 Apr 21st, 2004 06:13 AM
New recall on Fuel Pump for 2002-2003 Altima PhilGood L31 2002 - 2006 7 Aug 30th, 2003 09:53 AM
300zxTT Fuel Pump GA16DE Install Pics javierb14 Forced Induction & Nitrous Oxide 5 Jul 4th, 2003 02:21 AM
Installing 300zx Fuel Pump into a B14 holy200sx GA16DE 1.6L Engine 10 Jul 2nd, 2003 03:33 PM
