Help with Rear Wheel Bearing Replacement - Nissan Forums: Nissan Forum
» Auto Insurance
» Featured Product
Go Back   Nissan Forums: Nissan Forum > Nissan Models > Sentra, Pulsar, NX, B14 200SX > B15 2000-2006
Register Home Forum Gallery eBay Marketplace Insurance Active Topics Garage Search Today's Posts Mark Forums Read Auto EscrowAuto Loans
B15 2000-2006 2000+ Sentra including 2002+ SE-R and SpecV
NissanForums.com is the premier Nissan Forum on the internet. Registered Users do not see the above ads.
Old Jan 17th, 2013, 02:12 PM   #1 (permalink)
03 SER Spec V
Well, 233K on the odometer and time to replace the rear wheel bearings (Hubs I think in this case). I purchased the new hubs but there are no Lugs in them and the holes are not knurled to receive lugs.
Any hints, things I should know about replacing these bearings? Special tools needed?
Thanks in advance,
Slimbob
Slimbob
03 Spec V
Slimbob is offline   Reply With Quote
Old Jan 17th, 2013, 02:29 PM   #2 (permalink)
NF Mod
smj999smj's Avatar
They don't sell the hubs in this case with the wheel studs nor the sensor ring for the ABS, as applies. Both have to be pressed into/onto the hub. If you want new wheels studs, they are Nissan #43222-41B00. If you have ABS, you will need the sensor ring, Nissan #47950-4Z001.
Part Detail
smj999smj is offline   Reply With Quote
Old Jan 18th, 2013, 11:31 AM   #3 (permalink)
Thanks for the input!
I suppose I will need to buy some lug studs and it looks like there is a seal behind it.
Slimbob
Slimbob
03 Spec V
Old Jan 18th, 2013, 12:11 PM   #4 (permalink)
NF Mod
smj999smj's Avatar
That's not a seal; that's the ABS sensor ring in the pic.
Old Jan 22nd, 2013, 09:45 AM   #5 (permalink)
SMJ999SMJ,
Yes, ABS sensor ring. I thought of that while I was at the Parts store.
You wouldn't happen to know the size of the spindle locknut would you? I have 32mm but that was too big. Maybe a 28mm or smaller.
Thanks,
Slimbob
Slimbob
03 Spec V
Old Jan 22nd, 2013, 05:12 PM   #6 (permalink)
NF Mod
smj999smj's Avatar
Probably a 30mm.
BB code is On
Powered by vBadvanced CMPS v3.2.2
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
Garage Plus vBulletin Plugins by Drive Thru Online, Inc.
