» Sponsors
» Sponsors
Go Back   Nissan Forums: Nissan Forum > Nissan Models > Sentra, Pulsar, NX, B14 200SX > B15 2000-2006
B15 2000-2006 2000+ Sentra including 2002+ SE-R and SpecV
Old Sep 10th, 2009, 02:28 AM   #1 (permalink)
Red face Check Engine light
My Check engine light is on.
And the car won't rev, I'm currently getting a max of 50kmph.
My mech says I should replace my MAF Sensor for around 450$. I have tried cleaning it (used a carb cleaner) but to no avail.
Is there any other reason why the check engine light would be on ?
Why did cleaning the sensor not work ?
kendirangu is offline   Reply With Quote
Old Sep 10th, 2009, 08:12 AM   #2 (permalink)
Nissan Technician
vrefron's Avatar
I'd need more info to be sure, but it sounds like a MAF to me. Sometimes they break, and cleaning doesn't always work. It's an electronic part. Do you clean your motherboard if your computer breaks?
Now playing: Pink Floyd - Childhood's End
via FoxyTunes
vrefron is offline   Reply With Quote
Old Sep 10th, 2009, 08:19 AM   #3 (permalink)
i had a P1446 trouble code and i used a carb cleaner on the EVAP Canister Vent Control Valve...it worked.. it airs out.. good luck kendirangu.
JOHNYSLEEPERB15 is offline   Reply With Quote
Old Sep 10th, 2009, 09:48 AM   #4 (permalink)
Post Freak
if you can get it by a Auto Zone, they will scan it for you so you will know for sure...
SPEEDO is offline   Reply With Quote
Old Sep 10th, 2009, 09:30 PM   #5 (permalink)
Nissan Addict
saint0421's Avatar
Send a message via MSN to saint0421 Send a message via Yahoo to saint0421
if while driving you cannot go past ~2k rpms then your car is in safe mode. do as suggested and get the code read. that will assist in helping to troubleshoot your issue
So. . . Your face is dumb!
saint0421 is offline   Reply With Quote
Old Sep 10th, 2009, 10:50 PM   #6 (permalink)
Nissan Fanatic
Of course he would say that, especially if he was pulling ideas out of his ass. Did he/she happen to mention a diagnostic code or whether or not he used a code scanner of any type to come to that conclusion?
Only about 10,000 or more other reasons... But most won't limit your engine rpm's or necessarily cause the engine to act up negatively.
Why WOULD cleaning the sensor work? If a wire broke internally, why would cleaning that broken wire clear the malfunction? If I smashed the MAF into tiny bits with a sledgehammer, would cleaning the MAF sensor bits and pieces make it work again? Sure, cleaning the MAF has worked for some people (including me), some of the time, but it's not a 100% 'be all end all' solution every time...
jdgrotte is offline   Reply With Quote
Old Sep 16th, 2009, 03:37 PM   #7 (permalink)
my cel is on too and is sshowing maf sensor but my car is running fine...its just using more gas.so i dont know whats up but if you find ne thing out let me know cause its driving me nuts...we put a new header on it and ever since its been on.
specvchick07 is offline   Reply With Quote
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
