Links
Go Back   NissanForums.com > Nissan Models > Sentra, Pulsar, NX, B14 200SX > B15 2000-2006
B15 2000-2006 2000+ Sentra including 2002+ SE-R and SpecV
Old Sep 6th, 2007, 12:29 PM   #1 (permalink)
sonixtwo
Help with engine code 0456 - EVAP VERY SML LEAK
I recently got a 2004 Sentra 1.8S. This last week or so, my Check Engine Light has been on. When I pull the code, I get 0456, which is EVAP VERY SML LEAK.
I have been unable to identify what is causing this problem.
The first thing I checked it the gas cap, and it is on securely. Inspecting the vacuum system visually as best I could, I saw nothing wrong either.
After I reset the code, while driving, if I release the accelerator just a little bit while cruising, the engine light lights up, but does not stay on. I can easily recreate this situation at any time. After restarting the car, the engine light stays solid until I reset it again.
Any information on what can cause this problem would be appreciated.
Thanks
-Mike
sonixtwo is offline   Reply With Quote
Old Apr 17th, 2008, 05:23 PM   #2 (permalink)
chelito92105
This post might be a little late but I recently also had an EVAP Circuit Open SES light on my car. The car had been hit in the rear and one of the hoses was pretty much going nowhere. It was originally just plugged up so I put a piece of plastic with some electrical tape and a zip tie and the SES light never came on since. My advice is check all the hoses in the rear under the gas filler and make sure none of them are cracked or anything. Also check your carbon box to make sure its sealed.
chelito92105 is offline   Reply With Quote
Old Apr 20th, 2008, 11:59 AM   #3 (permalink)
djkid
djkid's Avatar
there is small black box. right under the bumper behind the wheel on the right side. make sure both the hoses are in properly and securely. if the problem is still there you might have to change your Evap cannister which is that black box.
Dj KiD
05 Sentra
18inch Chrome Rims. Uneasy Ride
djkid is offline   Reply With Quote
Old Apr 21st, 2008, 03:06 PM   #4 (permalink)
chelito92105
Yeah luckily the code stayed off until after the smog check but now it came back. This time with a "big leak." Im guessing Ill just replace the whole cannister now since it was probably impacted there. Any idea how much they would cost? I was thinking about a junkyard. Are all the boxes for the B15s the same? or are the SE-R ones different?
Old Apr 21st, 2008, 11:22 PM   #5 (permalink)
specv79
Cool me too evap small leak
I had the same trouble with this 2002 spec-v I bought recently I've put 1000.00 in nissan parts and 7 hours labour at a rate of $75.00. I replaced the evap cannister, both 02 sensors, evap control senor, valve, catalytic convertor. I was flashing the same codes p0456.
Now I got a new problem hard starting. p0301 misfire cylinder 1. I'm going to switch the coil packs (1 with 4) and see what happens. I might have a bad coil pack my sentra has 200,000km with original ignition. Anyone know how long these units last? anyone had to replace coil packs afther 10),ooomiles?
specv79 is offline   Reply With Quote
Old May 2nd, 2008, 01:49 PM   #6 (permalink)
djkid
djkid's Avatar
how much did the catalytic convertor cost you. im getting an SES on that code. thanks
Dj KiD
05 Sentra
Old May 2nd, 2008, 08:04 PM   #7 (permalink)
revoltrise
before you buy a new canister, take a look at the current one, and on the back side you'll see a valve with an electrical connector and two 3/8" rubber hoses going into it. pull that out of the canister and shake it around, if it rattles then you'll need to replace it. it is the evap vent control valve, and they go bad all the time. if it doesn't rattle make sure you lube the o-ring with silicone or wd-40 before you put it back into the canister, a leak there can also cause an evap leak.
revoltrise is offline   Reply With Quote
All you ever wanted to know about your Check Engine Light but were afraid to ask JKWright L31 2002 - 2006 159 May 13th, 2008 09:58 PM
Any EVAP experts? Code P0446 dtom4 Pathfinder 3 Feb 22nd, 2007 05:50 PM
about the check engine code when you put a header on? Spec V 2 fast QR25 2.5L Engine 13 Mar 17th, 2006 12:44 AM
How-To Detail Your Engine Exalta Car Care 24 Oct 17th, 2005 08:58 AM
'01 Pathfinder Check Engine Light Code hbarry26 Pathfinder 6 Jun 21st, 2005 07:29 PM
