Go Back   NissanForums.com :: Nissan Forum > Nissan Models > Sentra, Pulsar, NX, B14 200SX > B15 2000-2006
B15 2000-2006 2000+ Sentra including 2002+ SE-R and SpecV
Old Sep 21st, 2006, 09:29 AM   #1 (permalink)
boiler47
Question Fuel gauge, speedometer tach problem
Our 03 Sentra just recently started having the speedometer, fuel gauge and tach all started working periodically. Has anyone else had this problem, if so how did you fix it?
It appears all three instrument gauges are on the same circuit. Any help is greatly appreciated.
boiler47 is offline   Reply With Quote
Old Sep 21st, 2006, 09:45 AM   #2 (permalink)
TeKKiE
TeKKiE's Avatar
Boiler, can you pull the cluster out and make sure your connections to it are secure? Mine had disconnected it self over time. (Different year sentra though) Just reconnected it and it seemed to work fine.
TeKKiE is offline   Reply With Quote
Old Sep 21st, 2006, 10:50 AM   #3 (permalink)
boiler47
Tekkie,
Thanks for the reply. What do you mean by cluster? Do you mean the wiring going into the fuse box under the dash? If not where is the cluster located?
Thanks again
Old Sep 21st, 2006, 02:06 PM   #4 (permalink)
TeKKiE
TeKKiE's Avatar
Cluster being your instrument cluster (Where your guages are)
Old Sep 22nd, 2006, 08:35 AM   #5 (permalink)
boiler47
Tekkie,
Thank you again. Is it hard to get to the cluster? Do you have to remove it to check the wiring, if so how do you remove the instrument cluster?
Boiler
Old Sep 22nd, 2006, 09:39 AM   #6 (permalink)
TeKKiE
TeKKiE's Avatar
Not sure on your particular model, but on mine, you remove two phillips screws from the top underside of the black plastic decorative piece. Pull it out gently so you don't damage any clips. Then once it's removed there are four screws holding the cluster in. Just remove them, and again be careful not to damage any clips or anything as you pull the cluster out. Once it's out, just verify that all of your connections are solid. You may also want to look for any physical burns on the traces.
You would also remove the cluster this way to change any lights that may have burnt out
87 300zx fuel problem? Gleno Z31 300ZX(T) 9 Jan 21st, 2006 01:57 AM
Electrical Problem - Gauge Indicators Stay on warrenballard Z31 300ZX(T) 2 Jan 8th, 2006 09:04 AM
maybe this can be added to the nitrous sticky? buffdaddy18 Forced Induction & Nitrous Oxide 4 Dec 15th, 2005 08:20 PM
Frontier Tach, Speed, fuel gage lights problem madmike56 Frontier 2 Jun 22nd, 2005 11:51 PM
Fuel gauge ace B13 91-94 chassis 3 Dec 24th, 2002 01:24 AM
