Go Back   NissanForums.com :: Nissan Forum > Nissan Models > Sentra, Pulsar, NX, B14 200SX > B15 2000-2006
B15 2000-2006 2000+ Sentra including 2002+ SE-R and SpecV
Old Jul 18th, 2006, 02:26 AM   #1 (permalink)
joe3575
2001 sentra engine dies during hot weather
The symptom has appeared four times in four years on identical trips from longview, Wa to San Jose.
July 2003: leave LONGVIEW 3:30 AM: engine dies near Red Bluff. Restarts in about ten minutes. It was hot there.
July 2004: Same hot weather engine dies again near Red Bluff. Restarts in ten minutes.
July 2005: Same weather, same place, engine dies--restarts in ten minutes.
July 2006: Ditto, ditto, ditto. This time no restart; engine turns over but does not run.
Prior to the engine dying engine temperature reads normal, gas tank more than 1/2 full. A common element is the high ambient temp in that area. Engine has never died under cooler weather conditions, only there during very hot weather.
I need an answer. HHHEEELLLPPP!!!!!!!!
joe3575 is offline   Reply With Quote
Old Jul 19th, 2006, 01:34 AM   #2 (permalink)
rps180
Nissan Tech
What engine do you have?
Have you ever tried to have a code reader hooked up to see if a trouble code might be stored in the ECM?
How many miles?
Ever did any sort of tune up?
I am going out on a limb here, but it sounds like you MIGHT have a ignition problem. If you have high miles and never did a tune up, you might want to check the condition of your spark plugs.
rps180 is offline   Reply With Quote
Old Jul 20th, 2006, 05:10 PM   #3 (permalink)
slhaas
Send a message via ICQ to slhaas Send a message via AIM to slhaas Send a message via MSN to slhaas Send a message via Yahoo to slhaas
It sounds like spirits near Red Bluff are trying to delay your trip!
Seriously, it could an ignition module overheating, or any one of many sensors, etc. Get the codes pulled.
slhaas is offline   Reply With Quote
Old Jan 2nd, 2007, 07:27 PM   #4 (permalink)
mr.speedB13
Send a message via Yahoo to mr.speedB13
yes get the codes pulled and check the fuel filter it could be starveing for fuel when it is hot
mr.speedB13 is offline   Reply With Quote
Old Jan 15th, 2007, 02:08 AM   #5 (permalink)
trixkid
you might have a bad heater core
trixkid is offline   Reply With Quote
Old Oct 24th, 2008, 01:07 AM   #6 (permalink)
ArtNismo
Resistance is high At High temperature. When it cools down it'll run again.
I think it's the Crankshaft Position (CKP) Sensor.
CKP gets hot, it shuts down. It'll be out of spark to ignite the fuel.
It's only a guess.... It needs to be test for signal from the CKP sensor.
ArtNismo is offline   Reply With Quote
engine flush vs Bilstein Engine Flush vs not at all ak47m203 Off Topic 7 Feb 21st, 2008 04:06 PM
Sentra 1.6 low idle on hot starting!!! lecrote GA16DE 1.6L Engine 1 May 4th, 2006 05:58 AM
My '93 Nissan Sentra E (pictures and story- VERY VERY LONG!!) oliverr87 Member Rides 5 Oct 26th, 2005 08:46 PM
1993 Nissan Sentra with more than 200,000 miles, without any overhaul !! Pablo14 B13 91-94 chassis 2 Oct 23rd, 2005 10:02 AM
Needs Help! 89 Sentra w/ CHECK ENGINE lit SENTRA-89s B11/B12/KN13 82-90 chassis 5 Jul 23rd, 2002 09:51 AM
