Go Back   NissanForums.com :: Nissan Forum > Nissan Models > Sentra, Pulsar, NX, B14 200SX > B15 2000-2006
B15 2000-2006 2000+ Sentra including 2002+ SE-R and SpecV
Old Jan 11th, 2006, 01:25 PM   #1 (permalink)
Xnaron
Cruise Control Shifting Problem on 2001 Sentra GXE
I have a 2001 GXE and it has had a problem since the day I bought it. The problem happens when cruise control is engaged and you go over a hill that requires the transmission to gear down. After the car goes over the hill and starts going down the other side it does not gear back up to the proper gear. It stays in the higher reving gear until I either turn cruise control off or press the resume button. Anyone else ever see this problem? The dealership tried to fix it when I first got the car but could not. They even replaced the entire cruise module. Nothing worked. I just gave up on getting it fixed as it wasn't too major of an issue. I am just curious to see if others have experienced this and got the issue resolved.
THanks,
Brendin
Xnaron is offline   Reply With Quote
Old Jan 11th, 2006, 01:34 PM   #2 (permalink)
Xnaron
Not sure if this is the right forum or not for this...
Old Jan 11th, 2006, 05:14 PM   #3 (permalink)
Jarek
g33k/gamer/QR nerd
Jarek's Avatar
Send a message via MSN to Jarek Send a message via Yahoo to Jarek
http://www.nissanforums.com/showthread.php?t=114668
Its not what you know, its who you know
05 Brilliant Aluminum Spec V - ES MMI's Recieved! pending install
04 Blackout Sentra 1.8s! = stock = Traded in 06/27/05!
http://myspace.com/rv_jd MYSPACE PROFILE PAGE
Jarek is offline   Reply With Quote
cruise control problem derf-n-fred B14 95-99 chassis 10 Sep 24th, 2007 02:04 PM
My 2001 Sentra GXE MyGXEisFaster Member Rides 6 Aug 24th, 2005 11:47 PM
My 2001 Nissan Sentra GXE 01GXESentra Member Rides 1 Mar 31st, 2004 03:33 PM
Turbocharged 2001 Sentra GXE dyno results chimmike Forced Induction & Nitrous Oxide 14 Aug 25th, 2003 10:37 AM
Is my cruise control possessed? (Or is this normal?) BillDawg B14 95-99 chassis 4 Jul 16th, 2003 12:43 PM
