Old Jul 18th, 2005, 04:44 PM   #1 (permalink)
gsparling
Tach Problems
I have a 95 nissan 200sx A/T.
My tach does not seem to work when i turn on the ignition it goes to 3000rpm and stays there when i switch the engine of it flops down sometimes to 9000 rpm sometimes to 0rpm it is not working at all has anyone else had this problem, if so how did you fix it any help would be greatly appreciated
gsparling is offline   Reply With Quote
Old Jul 18th, 2005, 07:41 PM   #2 (permalink)
Ninety-Nine SE-L
Please Shift Here
Ninety-Nine SE-L's Avatar
Send a message via AIM to Ninety-Nine SE-L
it could be rubbing against something. If you open up the gauge cluster, I'd wiggle it around a bit, but don't remove the needle.
Ninety-Nine SE-L is offline   Reply With Quote
Old Jul 18th, 2005, 07:48 PM   #3 (permalink)
azkicker0027
Cone Dodger
azkicker0027's Avatar
Send a message via AIM to azkicker0027
is this really a tach display and not a surging idle issue??
Naturally aspirated autocross car.............naturally.
http://members.cardomain.com/azkicker0027 And defending STF in the process.
http://www.200sxonline.com/community/
azkicker0027 is offline   Reply With Quote
Old Jul 19th, 2005, 07:22 AM   #4 (permalink)
gsparling
Re: tach problem
I have open the instrument cluster and there seems to be no foul play, I dont know what to do next, it is not an RPM surge because I would hear it other than that the car runs beautifully
Old Jul 19th, 2005, 01:31 PM   #5 (permalink)
urquidezj
mine is all the way past 9k and i turn it on when i rev it it goes backwars to 8.4 or 9k rpms, its freakin weird.
urquidezj is offline   Reply With Quote
Old Jul 19th, 2005, 02:13 PM   #6 (permalink)
Ninety-Nine SE-L
Please Shift Here
mine goes just past 8k...oh wait that's normal
Um, I don't think there's a spring in there that makes the needle return to 0, the speedometer has one, but not the tach. It's possible the little motor in there is shot b/c the needle can only fall backwards (toward the 9k) when there's not enough electromagnetic force to move it back down the RPM range.
Old Jul 20th, 2005, 08:51 PM   #7 (permalink)
mk200sxser
Tachometer problems
I've been having the same problem with the tachometer as well. If anyone really does know of a fix, I'd like to know. Thanks. mk200sxser.
mk200sxser is offline   Reply With Quote
tach swap problems lovnyj B14 95-99 chassis 4 May 9th, 2005 10:37 PM
TACH PROBLEMS BIGPAPPA B13 91-94 chassis 5 Sep 9th, 2004 03:01 PM
Tach problems 88CHMPNGLD200 B13 91-94 chassis 4 Jan 9th, 2003 09:27 AM
tach problems antdagreat B11/B12/KN13 82-90 chassis 8 Nov 29th, 2002 06:20 PM
tach problems terry dibler A32 1995-1999 Chassis 7 Sep 3rd, 2002 10:47 PM
