Old Jul 13th, 2005, 12:05 PM   #1 (permalink)
derf-n-fred
cruise control problem
hello
i have a problem with my cruise control on my sentra 1999
i made a lot of test
first i check my pump (the resistance of my 1-3 1-4 2-3 pin)
i also check for my pump wire that ok
second i check my speed sensor --ok
also i check my brack pedal swich---ok
after i check my switch on and off ---ok
and my other switch with (cancel,coast,acel)-ok
afeter check all that mitchell on demand tell that we got to change the ascd module
i change it and that doesnt change anything
my cruise dont work yet
when i run i press cruise on and after that i press coast and my light (cruise) flashe
what can i do now
thank a lot i'm very tired about this car.....
derf-n-fred is offline   Reply With Quote
Old Jul 13th, 2005, 03:33 PM   #2 (permalink)
Twiz
TwiztidKidd
Twiz's Avatar
I'm sure your cruise control runs good. Adjust those two cables... your goal is too eliminate any play on both of them specially on the cruise control cable. They both have to be tight but the throttle has to stay closed at idle. Also follow the cruise control cable from the throttle body to the firewall and check all electrical connections and vacuum hoses in connection with this.
Twiz is offline   Reply With Quote
Old Jul 14th, 2005, 12:00 PM   #3 (permalink)
derf-n-fred
Thank i will try this an i give you some news about that
i hope this will be my problem...
Old Sep 13th, 2005, 08:20 AM   #4 (permalink)
derf-n-fred
I TRY TO ajuste my cable and my probleme is again there
so the only thing that is not change is my asdl module under the strerring colum...so please help my
thx
Old Sep 14th, 2005, 02:42 AM   #5 (permalink)
himilefrontier
265k miles and counting..
himilefrontier's Avatar
Send a message via AIM to himilefrontier
The blinking light on the dash would not likely indicate a loose cable, but rather a problem with the system somewhere. I would try to get the under dash module from a junkyard and see if that fixes the problem if you have tested everything else. Other than that, the only thing I can think of a maybe a bad VSS signal that is causing the problem. Maybe there is a trouble shooting guide in the B14 FSM ( stickied at the top of the B14 forum)?
1998 Nissan Frontier XE/2wd/5spd 1 owner, 264k miles
1985 Olds Cutlass, 350 Chevy, owned for 14 years
WANTED: 1968-1973 Datsun 510 or 1991-1994 Sentra SE-R
http://www.myspace.com/junkyardengineer
himilefrontier is offline   Reply With Quote
Old Jun 26th, 2007, 01:06 PM   #6 (permalink)
wgreene63
thx
There is a switch next to the brake light switch. It is actuated by the brake pedal. On the brake pedal there is a little urethane/rubber bumper. If that is gone then it will appear to the switch that the brakes are pressed. Any chance you found some rubber parts on the floor under your brake pedal?m On my 92 SE-R I found this urethane material and did not know where it came from. Then I noticed my cruise did not work. Then I noticed that my brake lights were staying on. I found these two switches (brake and cruise) were not making up because the rubber bumpers were gone.
Good luck, hope that helps.
wgreene63 is offline   Reply With Quote
Old Jul 19th, 2007, 11:51 AM   #7 (permalink)
slickser24
i have had the same prob with my 96 200 thanx for the help
slickser24 is offline   Reply With Quote
Old Jul 19th, 2007, 04:47 PM   #8 (permalink)
wgreene63
You are welcome/ Glad to help.
Old Sep 17th, 2007, 01:24 PM   #9 (permalink)
asd111
cruise control amplifier/steuergerät repair!
If the operation of your cruise control becomes intermittent and gradually results in a total failure to engage, then it is highly likely that the electronic module is at fault.
Please go to
E-mail: cruise.control.repair@gmail.com
webpage: Cruise control ECU, repair service and remanufactured units, Tempomat Steuergerät revision
They can help you!
asd111 is offline   Reply With Quote
Old Sep 17th, 2007, 10:49 PM   #10 (permalink)
Burn 17
Nissan Fanatic
Burn 17's Avatar
Send a message via MSN to Burn 17
when my b14 (ga) had these same symptomes it was just a vacume leak, i replaced the hose and fixed every thing, but now my vss is givin me Shiz so its out again only 6 months later
NEW!!1987 300ZX
200 sx auto cross beast--
Intake, Front and Rear Strut bars, Major exhaust leak.98style tail lights, clear corners, and halo angle eyes, Hot Shot headers/Downpipe(still need money for the rest of it)
Mazda B2200 Mini Truck
Burn 17 is offline   Reply With Quote
Old Sep 24th, 2007, 02:04 PM   #11 (permalink)
scooterbob
Send a message via MSN to scooterbob
I just checked my car that the cruise control hasn't work on for about 2 weeks. It was the little rubber bumper! That was a cheap fix and now I'm back to normal (whatever that was ) Thanks for the tip!
2008 Versa!
'95 200sx S-er: Homemade intake w/filter, 91 cams, advanced timing, 4 ga. grounding kit. (possibly for sale now)
If you ain't pinging redline MOVE! ---Bob
scooterbob is offline   Reply With Quote
Cruise Control NOT working.. sentravis B14 95-99 chassis 25 Nov 20th, 2007 04:24 PM
2004 & 2005 Armada brake problem Shannonop Titan & Armada 11 Aug 5th, 2007 02:33 PM
cruise control question?? 240droptop S13 240SX 1989-1994 2 Apr 12th, 2005 12:42 PM
Is my cruise control possessed? (Or is this normal?) BillDawg B14 95-99 chassis 4 Jul 16th, 2003 12:43 PM
Cruise control is posessed. WTF now? Ninety-Nine SE-L B14 95-99 chassis 7 Oct 31st, 2002 02:08 AM
