Old Nov 24th, 2002, 09:29 PM   #1 (permalink)
vksw
Posts: n/a
question about manual transmission...
Hi everyone,
I have '97 Sentra with manual tranny and sometimes when I shift into the 2nd gear it grinds a little bit. The mileage is 58K. I just wanted to know - is this a common issue with Nissan's manual transmissions? Does syncros often wear out at such mileage?
What's the price to rebuild a tranny?
Thanks for the answers.
Old Nov 24th, 2002, 11:09 PM   #2 (permalink)
CarbonBlack200
Platinum
CarbonBlack200's Avatar
Send a message via AIM to CarbonBlack200
Try to change tranny fluid. With Redline MT90. It has additive for syncros.
CarbonBlack200 is offline   Reply With Quote
Old Nov 24th, 2002, 11:49 PM   #3 (permalink)
dry
NF's Offical Post Whore
dry's Avatar
Send a message via ICQ to dry Send a message via AIM to dry Send a message via MSN to dry Send a message via Yahoo to dry
my 2nd has been grinding for quite a bit now but and my tranny fluid is full. I think it might just be the way I hit second or whatever. I'll look into that solution tho, thanks
dry is offline   Reply With Quote
Old Nov 25th, 2002, 08:57 AM   #4 (permalink)
97PocketRocket
Sadly enough, every car I've ever owned was a manual BUT my 200sx (/cry) but every one of them have had problems in second gear (not bad, just acts like you miss a gear or let out the clutch before getting the gear seated) after about 60-70k on the odometer, all different makes too so not one particular company, in every case it was the synchros but changing the fluid regularly does help significantly.
97PocketRocket is offline   Reply With Quote
Old Nov 25th, 2002, 02:16 PM   #5 (permalink)
vksw
Posts: n/a
So, am I gonna drive another 50K with this grinding (it's only sometimes)? As far as I understood, this is quite common?
Old Nov 25th, 2002, 03:32 PM   #6 (permalink)
zeno
Paging Mr. Herman
zeno's Avatar
Does it grind all the time? If that is the case I would probably check it out, probably not serious but constant grinding can't be all that good.
I am reminded of my old Eclipse that would constantly grind into 2nd whenever the car was cold. I don't know if this has anything to do w/ your problem but I thought I'd throw it out. Sorry not much help.
Garage Sale - buy my junk!!
My Car!
Dreaming of turbo..... :fluffy:
zeno is offline   Reply With Quote
Old Nov 25th, 2002, 03:57 PM   #7 (permalink)
Zimmy57
Posts: n/a
VK, my car does the same thing, i ordered ES shifter bushings and a pacesetter short shifter should get here some time in this or the next week, ill let you know if they help
Old Nov 25th, 2002, 07:24 PM   #8 (permalink)
vksw
Posts: n/a
To Zimmy - thanks, it will be interesting to find out.
To zeno - no, it does not do it all the time. Sometimes it does it when the car is cold, sometimes when it's warm. It does it mainly after I accelerate quickly on the 1st gear and then shift into the second.
