Old Apr 4th, 2005, 12:09 PM   #1 (permalink)
trav6612
HELP 96 Nissan sentra problem with idle
Does anyone have any ideas. My car is a 96 nissan sentra 2.0 liter engine. It is also a manuel transmission. It seems that when I get going it goes good, but when I slow down it begins to sputter, then it will die and has a hard time starting back up. I think it is the idle? Any ideas? If it is the idle where is it and what do I need to do to adjust it?
trav6612 is offline   Reply With Quote
Old Apr 4th, 2005, 12:52 PM   #2 (permalink)
nismo1.6
read this........
Originally Posted by mitch hedberg
escalators can never break...they can only make stairs
yea, this is 1.6pete.....whatchu want foo!
nismo1.6 is offline   Reply With Quote
Old Apr 4th, 2005, 05:46 PM   #3 (permalink)
Kindfiend
absolutely classic
Kindfiend's Avatar
I don't usually nitpick about these things, but I doubt your car has the 2.0 L(SR20DE). Unless you have a 96 200SX SE-R, you have the 1.6 (GA16DE). Unstable idle is a common problem, and if you search you will find as much information you need. Use search words like "idle", "IACV", "throttle body". Or look through old posts with titles like yours.
Kindfiend
01 Sentra GXE
92 SE-R
Kindfiend is offline   Reply With Quote
Old Apr 4th, 2005, 08:49 PM   #4 (permalink)
nismo1.6
you have heard of the sentra SE.....right?
Old Apr 4th, 2005, 10:22 PM   #5 (permalink)
Kindfiend
absolutely classic
Kindfiend's Avatar
Yeah, smartass. But they didn't have the 2.0 in it until 98.
Kindfiend
01 Sentra GXE
92 SE-R
Old Apr 4th, 2005, 10:31 PM   #6 (permalink)
nismo1.6
hmm, good call. no need for the crass remark though
Old Apr 5th, 2005, 12:10 AM   #7 (permalink)
wes
Wise Cracker
wes's Avatar
Send a message via AIM to wes
I am NOT trying to start crap here, but I gotta say, I would have said the SAME thing based on your first comment Nismo1.6. You came accross that way man. Anyway, no harm no foul, and the SR20 was not put in a B14 Sentra until 1998.
www.NissanPerformanceMag.com
JWT
www.notnser.com
Old Apr 5th, 2005, 04:36 PM   #8 (permalink)
Kindfiend
absolutely classic
Kindfiend's Avatar
It was just the way it was worded. No offense intended.
Kindfiend
01 Sentra GXE
92 SE-R
Old Apr 5th, 2005, 05:53 PM   #9 (permalink)
ditto0011
ditto0011's Avatar
Send a message via AIM to ditto0011
Hahahaha I love how someone asks a question at the top of the page, then as you go further down people stray more and more away from the original question! Priceless, Anyway trav, a few questions. what kind of shape is the call in overall? I had something like this happen, but it did it mainly when i first started the car. It was like there wasn't enough fuel getting to the engine, but when i put jumper cables to it, it started right up. It turns out the ring on the battery terminal was cracked all the way down, and was losing it's connection. Replaced it and haven't had the prob since... maybe check that. The idle is by those 2 wire cables that hook to the throttle body(i think?) there are like 4 little nuts(this is all on the ga16 so might be diff for u) on the cable, and u turn those to adjust the idle. really just losens/tightens the tension on that cable, try jacking around with that see if you can get it to idle at a constant NORMAL speed lol.
ditto0011 is offline   Reply With Quote
Old Apr 5th, 2005, 07:58 PM   #10 (permalink)
Nostrodomas
Im out of here!!!!!!!!!!
That is actually just to adjust the throttle cable tension. Yea you can adjust it that way, but its not the right way of doing it.
There is a idle adjustment screw under a small black cap on your throttlebody. Turning it counter clockwise will inrease the idle, clock wise will decrease the idle. But you also have to make sure you lock it into timming mode to adjust this.
Run the engine up to normal temperature.
Turn Off engine and disconnect throttle position sensor harness connector.
Start engine
.Rev engine (2,000- 3,000rpm) 2 or 3 minutes under no load, then run engine at idle
Adjust idle speed by turning idle speed adjusting screw.
Stop engine and re-connect throttle position sensor harness connector.
Now that being said, I dont think the idle speed is your problem. I would 1st start off with cleaning the IAC valve, and the throttle body. Cheap and easy to do. IF that doesnt work, report back, and well go from there.
Click here for instructions, and pictures.
Nostrodomas is offline   Reply With Quote
Old Apr 11th, 2005, 06:28 AM   #11 (permalink)
DanTheMan
Exclamation Thank GOD!!!!
A contributor that doesn't rip on people and actually answers a question!
Without giving demerits just for asking!
I'm sorry I don't agree with everyone all the time but damn, ban yourselves!
The above contributor and WES have my humble donkey bowing down on the floor!
He who claims he knows all is ignorant,
He who claims ignorance is on the path to enlightenment. Lao Tsu
DanTheMan is offline   Reply With Quote
Old Apr 11th, 2005, 08:54 AM   #12 (permalink)
wes
Wise Cracker
wes's Avatar
Man I don't think I personally attacked you to warrant posts in all threads. We can disagree and still get along can't we? Anyway lets stay on topic Dan, I at least, get your point... I think.
JWT
www.notnser.com
Old Apr 11th, 2005, 05:20 PM   #13 (permalink)
nizzan4u2nv
Nissan Addict
Do the usual suspects. New properly gapped plugs, wires, cap, rotor, adjust timing and idle(the correct way), clean the throttle body. Cleaning the egr hoses might help too.
B14/S14
nizzan4u2nv is offline   Reply With Quote
Old Apr 15th, 2005, 01:26 AM   #14 (permalink)
200sx_guy
I just wanted to clarify on the arguement up top.... the b14 sentra se didn't come with a sr20... the ve came with the sr20... the b15 99,00 and 01 se model came with the sr20
Current Cars:
'95 240sx
'95 200sx ser
'03 spec v
200sx_guy is offline   Reply With Quote
Old Apr 15th, 2005, 09:56 AM   #15 (permalink)
wes
Wise Cracker
wes's Avatar
HUH? The 98-99 Sentra SE had an SR20DE, as did the 99 and 00 Sentra SE although it used the roller rocker version of the SR20. NO US car came with a VE...
JWT
www.notnser.com
Replacing Thermostat 96 nissan sentra trav6612 GA16DE 1.6L Engine 3 Nov 18th, 2004 09:31 PM
91 nissan sentra..no go over idle nissansentra General Discussion 1 May 3rd, 2004 03:34 PM
94 Nissan Sentra 5th gear problem Help Please!!! crooker B13 91-94 chassis 9 May 1st, 2004 11:56 PM
Warning about Rodeo Nissan in Fresno FadedKM83 Southwest 8 Mar 30th, 2004 01:16 AM
96 Nissan sentra for sale in NJ CHEAPP Onewheelup11 New England/Mid Atlantic 1 Sep 18th, 2003 03:46 PM
