Old Mar 28th, 2005, 12:44 PM   #1 (permalink)
sentra gle 95
Question Overdrive problems?
I have a 95 Sentra GLE with a problem that doesnt happen all the time. The problem is sometimes the car runs at higher rpm's than other times. Example..1st day 60 mph @ 2200 rpm....next day 60 mph @ 3100 rpms. It did this to me a couple of months ago and stopped. It just started again yesterday. I can tell when it is going to happen because when I come to a stop the rpms will drop below 500. I thought maybe the overdrive switch, but when I turned it off the car ran at a much higher rpm. It is almost like the car has an extra gear. Could the overdrive be going out it self or could it be an electrical problem? Plus it only seems to do when it is hot outside. It did not do this all winter.......I appricate any and all help.
sentra gle 95 is offline   Reply With Quote
Old Mar 28th, 2005, 11:40 PM   #2 (permalink)
Nostrodomas
Im out of here!!!!!!!!!!
You wouldnt have any problem with start up do you. Like when you start the car, does it idle up then drop suddenly, almost dieing?
Nostrodomas is offline   Reply With Quote
Old Mar 28th, 2005, 11:47 PM   #3 (permalink)
Ninety-Nine SE-L
Please Shift Here
Ninety-Nine SE-L's Avatar
Send a message via AIM to Ninety-Nine SE-L
Well, first off, listen to the car and watch the RPMs. Is it going through all 4 gears? I've heard of constantly variable gear ratios, but I don't think our cars do that.
How long has it been since your tranny fliud has been flushed, sounds almost like the torque converter is slipping.
Ninety-Nine SE-L is offline   Reply With Quote
Old Mar 28th, 2005, 11:54 PM   #4 (permalink)
James
in^3,N20,RPM,PSI
James's Avatar
the torque converter is meant to slip. only when cruising at a steady rpm will the converter lock.
that's good advice though. listen to make sure you have all 4 gears. the automatic changes gear based on throttle position. if you floor the pedal from a stop you can get 1st gear to spin to 6200 rpm I believe before it will attempt to shift (if you shift manually you can hold it to 6900). if you give it half throttle it may shift at 3500 (its not a linear relationship)
oh and if you turn off the OD, it will rev higher because you're basically putting it into a lower gear... there's nothing wrong with that.
05 Frontier SE CC 4x4 (6spd)
Old Mar 28th, 2005, 11:58 PM   #5 (permalink)
Ninety-Nine SE-L
Please Shift Here
well, I mean it sounds like the torque converter isn't locking at all. It's only meant to slip at low RPM and at shifting.
Old Mar 29th, 2005, 03:25 PM   #6 (permalink)
sentra gle 95
Sometimes the rpms will drop real low on start up. They do however drop low everytime I come to a stop.
I had the tranny fluid changed about 20,000 miles ago. I only hear it shift through 3 gears.
Old Mar 30th, 2005, 12:06 AM   #7 (permalink)
sicksilver99
Send a message via AIM to sicksilver99
yeah change the transmission fluid, my friends over drive went out and he changed his transmission fluid and it worked again. overdrive is like a 5th gear and at startup it is supposed to be disengaged, then when the car starts to warm up it engages overdrive. so it could be electrical too.
<click here to see car> mods- cat back exhaust, driving lights, sony xplod stereo, audiobahn 10" subs, sylvania silverstars/ future mods- custom cold air intake, timing advance, amp for subs, headers
sicksilver99 is offline   Reply With Quote
Old Mar 30th, 2005, 08:54 AM   #8 (permalink)
Ninety-Nine SE-L
Please Shift Here
overdrive is not 5th gear...
Old Mar 30th, 2005, 10:52 PM   #9 (permalink)
sicksilver99
no i said its like a 5th gear. as in it acts like one
Problem/No Problems Zac QR25 2.5L Engine 69 Aug 25th, 2005 07:41 PM
Electrical problems cameron S14 240SX 1995-1998 0 Jan 30th, 2005 06:18 PM
Help! 95 SE Stalling/Hesitation Problems While Cold reeddy Truck & SUV 0 Nov 11th, 2004 12:20 PM
Overdrive on/off problems Dave114 B14 95-99 chassis 7 Aug 12th, 2004 07:20 PM
My Nissan 350Z Lemon w/Many Problems! C1 Bender Z33 350Z 2003+ 8 Aug 10th, 2003 03:43 PM
