Old Mar 20th, 2005, 09:10 PM   #1 (permalink)
sicksilver99
Send a message via AIM to sicksilver99
oil leak?
so i was looking through my oil change reciepts and on the last 2 in small letters on the bottom of the reciept it mentioned that there was an oil leak discovered. they never told me about it when i was there and my car does not burn oil or run low on oil. the oil pan is oily but it never has dripped oil on the ground. should i worry about this? im adding some oil leak additives to my oil just to be sure. im going to start changing my own oil now anyways, those bastards over filled it last time.
<click here to see car> mods- cat back exhaust, driving lights, sony xplod stereo, audiobahn 10" subs, sylvania silverstars/ future mods- custom cold air intake, timing advance, amp for subs, headers
sicksilver99 is offline   Reply With Quote
Old Mar 20th, 2005, 09:34 PM   #2 (permalink)
Kindfiend
absolutely classic
Kindfiend's Avatar
Good for you learning to work on cars! Take it slow, make sure you do every step, and use a torque wrench to tighten bolts to spec. This will save you a lot of trouble later on, especially if you are like me and wing it half the time.
If there is oil on the pan, I would first look at the front main seal. That's a very common spot for our cars to leak. Fortunately, its easy to replace. If you look on the passenger side of the car, underneath where the belts are, you will see a pulley with two belts attached to it. You have to remove the pulley to get to the seal, but it's a good place to check for leaks.
On a side note, those oil additives are no good in my opinion. Fix the problem, not the symptom. Good luck wrenching!
Kindfiend
01 Sentra GXE
92 SE-R
Kindfiend is offline   Reply With Quote
Old Mar 20th, 2005, 09:52 PM   #3 (permalink)
sicksilver99
i know how to do the basics on working on my car like a tune-up, and electrical wiring but i have no idea how to replace the front seal (nvmd, found a sticky), but is it worth it to replace, i mean i havent had any problems with it like that.
Old Mar 20th, 2005, 09:55 PM   #4 (permalink)
sicksilver99
that would also probably explain my belts squeaking sometimes when i start it up. wouldnt it?
Old Mar 21st, 2005, 12:28 AM   #5 (permalink)
Tavel
Destroyer of worlds.
Tavel's Avatar
Send a message via AIM to Tavel
im gonna have to disagree with kinfiend here. some oil additives are effective at repairing minor leaks. one that comes to mind is auto-rx, but any similar agent will do the same thing.
seals are "inflated" by oil, thus sealing the gaps. (if it doesnt make sense, think of a wooden boat. wood expands when wet, so the gaps between boards are sealed by wetting the wood...simple). sometimes the seals get gunked up and oil can't reach them, at which time they dry out. dry seals dont work. proper oil additives will clean the gunk away, freeing oil to reinflate the seals.
but again, this only works on MINOR leaks. if the seal is physically damaged/cracked it will not work.
the belt squeaking could be caused by oil, it could also just be age. you may want to replace them if they're still original.
I'll edit YOUR signiture!
Tavel is offline   Reply With Quote
Old Mar 21st, 2005, 05:53 PM   #6 (permalink)
Kindfiend
absolutely classic
Kindfiend's Avatar
Huh, I always figured those stop leak additives were just thicker oil to help plug up any holes that the lighter oil can get through. Maybe a conditioner for the seals, but no more than that. Anyways, I've heard good things about auto-RX. I can't imagine it could do much harm if you used it.
And yeah, oil on the belts will definitely shorten their life quickly.
Kindfiend
01 Sentra GXE
92 SE-R
Old Mar 21st, 2005, 09:32 PM   #7 (permalink)
Hydrolock
Although the front main seal is very common I would start by checking the easier things. Is the valve cover on tight, is the gasket leaking, is the oil filter tight, are the bolts on the oil pan tight, is the gasket leaking, oil cooler lines, drain plug gasket, then I would move to something like the front main seal.
Hydrolock is offline   Reply With Quote
Old Mar 21st, 2005, 10:19 PM   #8 (permalink)
sicksilver99
i looked over everything today when i was replacing my spark plugs, and its that front seal. its leaking so very little, not even to drip just get all over the oil pan and the skid plate, and yes theres some oil on the belts. the belts are pretty new though, they look alright, and have been replaced about 15k miles ago. i added some engine restore to my oil, thanks for your help
Old Apr 26th, 2005, 07:15 PM   #9 (permalink)
amar67
I just picked up a 98 200sx and have the same exact problem. have lost about 1/3 qt. of oil in about 200 miles of driving and get a constant belt squeal when reving above 3k. When I changed the oil, I cleaned all around the pan, and checked as many of the pan bolts as I could get a socket on. all felt nice and snug. after cleaning, I checked all around and the leak is fresh and directly to the right of the pan right below the pully.
From reading several threads it looks to be the front main seal and also sounds like it is an easy fix. I would like to do it myself but the haines manual does a very poor job in describing the work. does anyone have a good set of insturctions? also, looks like the belts are in a very tight spot, any suggestions? I believe one person said they did it in an hour.
Thanks,
amar
amar67 is offline   Reply With Quote
Old Apr 26th, 2005, 07:27 PM   #10 (permalink)
lshadoff
Post Freak
lshadoff's Avatar
Thanks,
amar
Read the sticky thread at the top of the GA16DE forum:
http://www.nissanforums.com/showthread.php?t=70714
Lew
lshadoff is offline   Reply With Quote
Old Apr 26th, 2005, 08:22 PM   #11 (permalink)
BlackNismo95
BlackNismo95's Avatar
Send a message via AIM to BlackNismo95
Thanks,
amar
I didn't have the time to replace the front seal myself due to work, So I got a mechanic to do it for me, book listing in the labor guide is 1 hour, it took them a little under an hour. while i was right there I had the new belts put on as the other are crap from all the oil. They squeaked almost every time i started the car.
86 300zx - N/A 5 Speed - accel plugs and wires - Mallory ignition - Digidash - Monza exhaust
*new paint in progress - just got car
BlackNismo95 is offline   Reply With Quote
Best Engine Oil???? MCHNHED B14 95-99 chassis 70 May 15th, 2008 05:21 PM
Limited time showing, come one come all!! Marvin Off Topic 43 Jan 14th, 2005 07:35 PM
oil switch leak shughes GA16DE 1.6L Engine 4 Oct 25th, 2004 04:33 PM
puzzling oil leak (around crankshaft) shughes GA16DE 1.6L Engine 6 Feb 8th, 2004 01:50 PM
My first engine oil leak 96R50 Truck & SUV 17 Dec 31st, 2003 06:12 AM
