Old Mar 3rd, 2005, 07:36 PM   #1 (permalink)
sicksilver99
Send a message via AIM to sicksilver99
timing advance help
i know this has probably been discussed before, but i searched and i couldnt find the answer. Anyways, i went to a mechanic to get my timing advanced and he said that it would be a waste of time to get my timing advanced on my car, because the ecu would just retard it back to where it should be. Is this true or is he just stupid? btw i was reccomended to this mechanic by another mechanic specifically for timing advance.
<click here to see car> mods- cat back exhaust, driving lights, sony xplod stereo, audiobahn 10" subs, sylvania silverstars/ future mods- custom cold air intake, timing advance, amp for subs, headers
sicksilver99 is offline   Reply With Quote
Old Mar 3rd, 2005, 07:47 PM   #2 (permalink)
Token Moron
My ass, your face
Token Moron's Avatar
Send a message via AIM to Token Moron Send a message via MSN to Token Moron
depends....if it is advanced too far, the knock sensor would warn the ecu which would knock it back to stock specs..but if its advanced to 15* then there would be no harm(as long as u run premium fuel)
91 se-r : sr20det= the beast
96 sentra : ga16de= pimpness
00 frontier : ka24de= tow truck
01 sentra : gq18de= stock mofo
Token Moron is offline   Reply With Quote
Old Mar 3rd, 2005, 09:03 PM   #3 (permalink)
sicksilver99
so as long as i run premium fuel and advance it to just 15*, the ecu wont retard it back to 10*. i told the guy that and he seemed pretty convinced.
Old Mar 3rd, 2005, 09:10 PM   #4 (permalink)
wes
Wise Cracker
wes's Avatar
Send a message via AIM to wes
The ONLY way it pulls timing is if the knock sensor detects problems. The car does NOT KNOW what base timing is at, as it is mechanical. He is wrong...
Advance it to 15 degrees and run premium fuel.
www.NissanPerformanceMag.com
JWT
www.notnser.com
Old Mar 3rd, 2005, 09:26 PM   #5 (permalink)
sicksilver99
ok thanx, i was confused for a sec, ill just go to another mechanic, i dont want to do it myself im too lazy
Old Mar 4th, 2005, 09:37 PM   #6 (permalink)
Ninety-Nine SE-L
Please Shift Here
Ninety-Nine SE-L's Avatar
Send a message via AIM to Ninety-Nine SE-L
You should take the 2 TPS sensors off to get into "timing mode." With the car running, pull the TPS plugs from the throtte body. It will not throw the CEL, you'll hear the tone of the engine change, then it'll adjust itself accordingly. Rev the engine 2-3 times past 2,000rpm, then adjust. Make sure you don't have any accessories on and the fans are not on when you check the timing light.
If you can borrow a timing light, just do it yourself, it takes about 10 minutes, all you need is a 12" socket and a flat head. It's not worth paying someone to do it.
Ninety-Nine SE-L is offline   Reply With Quote
Old Mar 4th, 2005, 10:02 PM   #7 (permalink)
Token Moron
My ass, your face
there is only one TPS. You have to unplug the TPS while the car is OFF, then turn the car on.
Old Mar 4th, 2005, 10:03 PM   #8 (permalink)
lshadoff
Post Freak
lshadoff's Avatar
Notes:
- Sometimes the engine will not idle in timing mode. If this happens, start the engine and hold the accelerator to keep the engine running at idle speed while adjusting the idle speed screw.
- Advancing the timing makes the engine run faster, so the idle must be adjusted after changing the timing.
Here is the procedure from the B14 Factory Service Manual
Timing
1. Warm up the engine until the temperature gauge points to the middle
2. open the hood and run the engine at about 2000rpm for about 2 minutes under no-load.
3. Rev engine two or three times under no-load and then run at idle speed for about 1 minute.
4. Turn off the engine and disconnect the throttle position sensor harness connector.
5. Start engine.
6. Rev engine (2000-3000 rpm) 2 or 3 times under no-load, then run engine at idle speed.
7. Check ignition timing with a timing light.
7a. Adjust ignition timing to the desired value by turning the distributor after loosening bolts which secure the distributor.
Idle
1. Rev engine (2000-3000 rpm) 2 or 3 times under no-load, then run engine at idle speed.
2. Adjust idle speed by turning idle speed adjusting screw.
M/T 625 +/- 50 rpm
A/T 725 +/- 50 rpm (in "N" position)
3. Stop engine and connect throttle position sensor harness connector.
4. Start engine
5. Rev engine (2000-3000 rpm) 2 or 3 times under no-load, then run engine at idle speed.
6. Check idle speed.
Lew
lshadoff is offline   Reply With Quote
Old Mar 4th, 2005, 10:07 PM   #9 (permalink)
James
in^3,N20,RPM,PSI
James's Avatar
newer model b14's sometimes had two tps sensors (mexican built b14's)
05 Frontier SE CC 4x4 (6spd)
Old Mar 4th, 2005, 10:13 PM   #10 (permalink)
Ninety-Nine SE-L
Please Shift Here
my SR and my old 97 had 2 TPS plugs.
I disconnect the TPS with the car on, never had any problems.
Old Mar 4th, 2005, 10:36 PM   #11 (permalink)
lshadoff
Post Freak
lshadoff's Avatar
Well, sicksilver99, you have a choice. You can follow the factory recommended procedure or the one posted by Ninety-Nine SE-L. I am confident that the factory recommends turning off the engine before disconnecting the sensor for a reason, but that's just me, a person who was working on cars before Ninety-Nine SE-L was born.
It seems to me that having two throttle positition sensors would require having two throttle bodies each with a throttle to sense. It's hard to believe the factory put duplicate sensors on the same throttle.
Lew
Old Mar 4th, 2005, 10:38 PM   #12 (permalink)
James
in^3,N20,RPM,PSI
James's Avatar
Lew
I don't believe its two sensors. I think its just one sensor with two plugs for some reason. Started in 97 vehicles.
Old Mar 4th, 2005, 10:48 PM   #13 (permalink)
lshadoff
Post Freak
lshadoff's Avatar
My '97 FSM doesn't think so. It shows a single 3-wire connector for both the GA and SR engines.
Lew
Old Mar 4th, 2005, 10:51 PM   #14 (permalink)
wes
Wise Cracker
wes's Avatar
Lew
Honestly lew, James is correct. I have both throttle bodies and sensors to prove it. I am not 100% certain that both of them have to be disconnected but I GUARANTEE they connect at the throttle plate.
JWT
www.notnser.com
Old Mar 4th, 2005, 11:08 PM   #15 (permalink)
lshadoff
Post Freak
lshadoff's Avatar
There are only three wires to the TPS, one of them is shielded.
My SR has one 3-wire connector to the TPS and separate ones further down the cable for the shield ground and signal to the A/T computer.
The GA wiring diagram shows one 3-wire connector to the TPS and a separate one for the shield ground.
Disconnecting the 3-wire connector on either of them isolates the TPS.
Lew
advance timing running 89 octane ricerboy17 B13 91-94 chassis 8 Jan 12th, 2005 02:34 PM
timing advance altimobile L31 2002 - 2006 11 Mar 14th, 2004 08:10 AM
Advance Timing on '97 Sentra GXE with 1.6L stevja1 New Member Forum 6 Jan 29th, 2004 11:28 PM
Question about Knocking and Timing advance 200sxOuTKasT GA16DE 1.6L Engine 7 Dec 3rd, 2003 06:27 PM
Timing Advance??? t78silvia S13 240SX 1989-1994 1 Nov 11th, 2003 08:18 PM
