Old Mar 3rd, 2005, 12:48 AM   #1 (permalink)
AnthMC
Send a message via AIM to AnthMC Send a message via Yahoo to AnthMC
Help, I think my Alternator is going out
Hey everyone, don't laugh at my question but I just want to be sure I replace the right part here...... I just put a new/used battery in my car like 3 -4 months ago after having the stock one in there since I bought the car in 99. Now my stereo light keeps dimming and turns off and back on usually when the car is comming to a stop or when I'm not giving it gas. Keep in mind I have an amp running on there too...... Is this an alternator problem?? Sounds like it to me..... and its still stock but just want to make sure.... thanks for all your help!!!
AnthMC is offline   Reply With Quote
Old Mar 3rd, 2005, 01:04 AM   #2 (permalink)
Token Moron
My ass, your face
Token Moron's Avatar
Send a message via AIM to Token Moron Send a message via MSN to Token Moron
sounds like a battery to me....usually when the alternator is starting to go bad, u will see the brake and battery lights on the dash light up simultaneously..
91 se-r : sr20det= the beast
96 sentra : ga16de= pimpness
00 frontier : ka24de= tow truck
01 sentra : gq18de= stock mofo
Token Moron is offline   Reply With Quote
Old Mar 3rd, 2005, 06:30 AM   #3 (permalink)
B14_Stealth
new motor & tranny
B14_Stealth's Avatar
Send a message via AIM to B14_Stealth
take a tester and test the battery when the car is on and running with a load, like headlights ..radio..etc . If the alternator is charging perfectly..then it would say AT LEAST 13 Volts but most of the time its closer to 14. When the car is not running the battery would probobly read somewhere between 12 and 12.5V.
B14_Stealth is offline   Reply With Quote
Old Mar 3rd, 2005, 09:19 AM   #4 (permalink)
Ninety-Nine SE-L
Please Shift Here
Ninety-Nine SE-L's Avatar
Send a message via AIM to Ninety-Nine SE-L
hahahahahahahahahahahahahahahaha <---you told me not to laugh, so I did anyway
joking.
It could be the alternator, I would expect the new battery to work just fine. Any car place can test your battery and diode for free, try checking there.
Ninety-Nine SE-L is offline   Reply With Quote
Old Mar 3rd, 2005, 11:26 AM   #5 (permalink)
Tavel
Destroyer of worlds.
Tavel's Avatar
Send a message via AIM to Tavel
like b14 said, you can test it yourself.
you need a voltmeter of course. start with the car off, put the two leads of the meter on the two leads of the battery, it should read 12v.
now turn the car on and do the same thing, it should now read 14v
if its low with the car off then its the battery, if its low with the car on then its the alty.
I'll edit YOUR signiture!
Tavel is offline   Reply With Quote
Old Mar 3rd, 2005, 01:17 PM   #6 (permalink)
wes
Wise Cracker
wes's Avatar
Send a message via AIM to wes
If the car runs better with the RPM's increased then I would say it's the battery. You said new/used well that says used to me. I would test it first as stated then check the alt.
www.NissanPerformanceMag.com
JWT
www.notnser.com
Old Mar 4th, 2005, 12:36 PM   #7 (permalink)
AnthMC
Yea that's what I was thinking of more along the lines of the battery. This one guy that is my roommate was trying to be nice and put this piece of Sh*** older battery in when I would have just went out and bought one. The factory battery lasted me a good 5 years. I'll test it first and see what happens!! Thank you for your help and I'll let you guys know how it goes!
