Old Mar 1st, 2005, 08:37 PM   #1 (permalink)
dlonnie
99 sentra gxe starter problem
My sentra occassionlly has a problem starting. My father thought that it was attributed to water in the fuel line because after 15 minutes of continully trying to get the engine to turn over it would. This time however after repeatedly trying to start it it whent from cracking to just a clicking. I thing i fried the starter. Where is the starter anyway?
Need some help
embarrassed science teacher
dlonnie is offline   Reply With Quote
Old Mar 1st, 2005, 10:06 PM   #2 (permalink)
Kindfiend
absolutely classic
Kindfiend's Avatar
Need some help
If it's just clicking and not turning over then it may be your starter. They do have a tendency to go on our otherwise reliable cars. The starter is below the throttle body on the transmission. Look for the ground cable on the battery and follow it down in the engine bay. The other end is connected to the starter on the bottom bolt. I'm curious to know about the cracking noise you describe, however. If the car doesn't want to start, give the starter a few taps with a tool, wrench, hammer, ect. If it starts right up after, then your starter will need to be replaced. If not, then more diagnostics will be in order.
Good luck
Kindfiend
01 Sentra GXE
92 SE-R
Kindfiend is offline   Reply With Quote
Old Mar 2nd, 2005, 11:52 AM   #3 (permalink)
IanH
Post Freak
IanH's Avatar
Good luck
Also clicking is a sign of a flat or bad battery, so check that the battery is charged.
If this is a B14 GXE 1.6GA the starter is above the transmission below the air box by the clutch operating lever.
Its in a different place to the SR20 cars and the 1.8 gxe.....
Also the bolts are weird, one from each side...
Ditto on the question about the cracking.....
When you say after 15mins it finally turns over, I assume you mean it does not turn over for 15 mins, meaning its not cranking or turning ?????
Also bad cable could be the cause of not cranking.
Definitely try giving the starter a good wack.... a hammer is good...
1997 Sentra GXE .... For Sale 104K miles
1997 S-ER 5 sp yea !!!
2003 Pathfinder SE 4WD
IanH is offline   Reply With Quote
Old Mar 2nd, 2005, 02:58 PM   #4 (permalink)
KuMardagg
I'm also experiencing some trouble starting my GXE. It sounds very rough and "chugs" when when starting. Instead of the quick, high-pitched turnover sound, it's a laggy, low-pitched grinding noise. Occasionally it simply does nothing when the key is turned, beyond a single click.
I'll have to try this starter-whacking technique. I'm driving the 99 GXE 1.6L GA16DE, but I'm terribly unfamiliar with all things car-related... Can anybody point to a diagram of the major engine components? I want to make sure I'm beating on the right part.
*edit* downloading FSM.zip, no need for diagram
KuMardagg is offline   Reply With Quote
Old Mar 2nd, 2005, 03:09 PM   #5 (permalink)
Wufaded
THINK BLUE
Wufaded's Avatar
Send a message via MSN to Wufaded
Check out this thread, it has some pics and diagrams regarding starter location on a GA16DE..
http://www.nissanforums.com/showthread.php?t=83385
Club MoFo Votary - My 200SX
Wufaded is offline   Reply With Quote
Corner lens broken on '99 Sentra civic4982 B14 95-99 chassis 9 Jun 21st, 2004 05:47 AM
About to buy a '99 Nissan Sentra civic4982 B14 95-99 chassis 15 Jun 17th, 2004 04:14 PM
nissan sentra 1996 starter Dimas General Discussion 3 May 27th, 2004 06:49 PM
MAF adapter on 99 GXE SentGXE99 GA16DE 1.6L Engine 6 May 8th, 2004 01:55 PM
Should I trade or sell my '99 GXE to get a '99 SE-L? Bach42T B14 95-99 chassis 6 Jan 16th, 2003 12:03 AM
