Tail light Problem - Nissan Forum
post #1 of 20 Old Feb 8th, 2005, 06:42 PM Thread Starter
Unhappy Tail light Problem
I have a problem with the tail lights on a 97 Sentra. I replaced the socket assembly on the right hand side, now I have no tail lights whatsoever. The brake lights work but no tailights. I checked fuses but only found the fuse for the brake lights anyone know where the fuse for the tail lights is located?
jwthompson1 is offline
post #2 of 20 Old Feb 8th, 2005, 08:08 PM
BadBoy91's Avatar
Do you have a service manual?
i think the tail lamps are on the sme fuse as the brakes though.
im not positive though. you need a servce manual though, a factory service manual at that.
chirp chirp chirp, chiirrp, Screeeech, SMASH!-- buy good tires.
BadBoy91 is offline
post #3 of 20 Old Feb 9th, 2005, 08:27 AM Thread Starter
I have an owner's manual if that is what you are referring to. I can't find any other fuses either. Another problem seems to have arose that is possibly related. The dash lights do not work either. I checked the fuse for it also. This is about to drive me crazy. Anybody have any ideas?
post #4 of 20 Old Feb 9th, 2005, 08:44 AM
Red line chaser
wickedsr20's Avatar
If the Sentra is wired like the 200 is, then you have a fuse under the hood that controls the tails and the front corner lights. I'd have to look under the hood to see what it's labeled as, but it's there in my car.
96 SE-R: SR20VE - bolt ons
97 SE-R: SR20DET 54C - on hold - need $$$
03 Altima SE V6: PR CAI/SS grill/alarm & remote start/100 sf Stinger Roadkill/
19's (need tires)/stereo going in next
wickedsr20 is offline
post #5 of 20 Old May 25th, 2005, 06:51 PM
Nissan Fanatic
huskya83's Avatar
Send a message via AIM to huskya83
car was just inspected and failed due to the tail light probleming i'm having. Seems to be blinking to fast.
anyways the lights for the brakes was not working, changed the bulbs and still the problem was there. turning singal works.
So i went and bought a new assembly but it was very different from what i had. The 2 sockets are there but it seems to be missing a switch/relay (looks like a little black box). I'm guessing i bought the mexican version or maybe its the american verison.
The brake light works but the tail lights blink too fast
B14 Sentra GXE' (federal)
Hotshot CAI, Hotshot Header, SE-R cat. convertor, Stromung
next:
17in. rims, kumhos, agx/ground control setup., koni bump stops,
huskya83 is offline
post #6 of 20 Old May 25th, 2005, 11:33 PM
Nissan Fanatic
huskya83's Avatar
is there no one that knows the answer to this??
i know there's a mexican verison and american verison
its the harness for the tail light, baiscally the socket .. that whole piece is different from what I have.
What i am looking for this the little black box piece that is missing.. I suppose this is the piece that controls the speed the tail light flashes. I have only been able to find the harness that doesn't come w/ it.
next:
huskya83 is offline
post #7 of 20 Old May 26th, 2005, 12:09 AM
nissan??? whats that
I'm Slow's Avatar
did u look under the hood at the fuse box near the battery there is a size 10 fuse that has probably popped
Timeline? Time is not made out of lines, it is made out of circles. That is why clocks are round...
IM SELLING MY STROMUNG for a 1.6 PM for pic's or "?'s"
I'm Slow is offline
post #8 of 20 Old May 26th, 2005, 12:32 PM
Nissan Fanatic
huskya83's Avatar
checked the fuse and its good. I changed it but i'll try it again today for good measure. My problem is that I found there are 2 different sockets for the sentra. The one i bought did not come w/ a part but still worked. just that the signal goes faster.
next:
huskya83 is offline
post #9 of 20 Old May 26th, 2005, 11:00 PM
I Live Here
IanH's Avatar
Are you saying your turn signal is blinking faster than normal?
This is normaly a sign that the other bulb has blown.
Check the FRONT turn signal bulb is working.
If this is Ok check you have the correct filament lighting up on the back housing. The flasher blinks fast when the load is too low, so if the parking lamp is working instead of the turn filament this could be the cause.
GoodLuck.....
2003 Pathfinder from 2004 SE 4WD
1997 SER 5sp Manual from new Rear Ended 2009 !!
Gone to the Knacker yard...
New ride 3.0 manual RWD not a Nissan !!! Gone 2016 from Hail damage.
1997 Sentra GXE from new .... Sold 2008
2001 Sunny N16 RHD from new (N16 Nissan Bluebird Sylphy) Sold
IanH is offline
post #10 of 20 Old May 27th, 2005, 11:52 AM
Nissan Fanatic
huskya83's Avatar
yes, the turn signals are blinking fast, all other lighting are fine.
i suppose my dad got the wrong bulb as the new sockets i bought are different from what i originally had.
i'll describe the sockets:
originally i had--
the main wiring, then some little black box , dividing into 2 sockets
what i bought--
the main wiring, diving into 2 sockets
when i was buying there was an option for the us version or the mexican verison ..
maybe the bulbs are different for the new sockets i bought..
i'll supply some pics after work.
next:
huskya83 is offline
post #11 of 20 Old May 27th, 2005, 01:23 PM
yesss...
UnkalledFor's Avatar
Send a message via AIM to UnkalledFor
originally i had--
what i bought--
check for a bad ground... alot of times this simple thing is the culprit..
UnkalledFor is offline
post #12 of 20 Old May 27th, 2005, 01:38 PM
99ryder718's Avatar
okay fix it like this
this is a very simple fix. you put the wrong bulb in the socket. you must have put a 1156 bulb which is single filament and you need a 1157 which is double filament. , it does the same thing when the bulb blows out. so make sure you have a bulb that has two dots on the bottom and not just one.
1156---are for rear turn signal lights. 1157 will make them blink fast ( one dot)
1157---is for front turn signals and brake/parking lights. (two dots)
hope this helps
99ryder718
Ninety9-ryder
99ryder718 is offline
post #13 of 20 Old May 27th, 2005, 03:57 PM
I Live Here
IanH's Avatar
originally i had--
what i bought--
Ok lets back up a bit.
Yes please post a picture. I have a 97 GXE federal car and will look at mine.
Why did you replace the sockets, do you still have the old one ?
Was it working OK before you changed the sockets.
I assume you have the correct bulbs. good post above.
Did you check the front lights ?
Good Luck.....
IanH is offline
post #14 of 20 Old May 27th, 2005, 08:32 PM
Nissan Fanatic
huskya83's Avatar
http://members.cox.net/alexander2/alexander2/socket
found it easier to just make a site..
anyways, the bulbs are doubled for the blinker and the brake light is singled..
99ryder718 are you saying that the blinker should be a single bulb (1156) not double bulb (1157)? cuz when you look at both sockets the blinker as 2 dots while the brake as 1 dot.
The reason i bought a new one was that the stop brake light was not working. the bulbs were changed and it later turned out that the brake socket was not working. I did some mismatching and found that solution. So, when i went to buy another socket, (off the internet) i found the socket on the right,.. noticed that it was not like the socket on the left but it still worked.
next:
huskya83 is offline
post #15 of 20 Old May 27th, 2005, 11:06 PM
99ryder718's Avatar
hold up
hold up..................you said a little black box. Are these factory lights of atfermarket lights. i had the euro tails and the little black you talkign about failed on me so i re-wired it then i just put back my stock tails with red tinted turn signal. stock tail lights don't have a little balck box, they plug right in the lights sockets. okay one more time
1157 are for brake lights and front turn signals
1156 are for rear turn signals
thats it
Ninety9-ryder
  Nissan Forum > Sentra, Pulsar, NX, B14 200SX > B14 95-99 chassis
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Linear Mode Linear Mode
Tail Light Problem BlazinSent B14 95-99 chassis 1 Feb 8th, 2005 03:00 PM
B13 "Engine" warning light...problem? Russellc B13 91-94 chassis 8 Jul 29th, 2004 08:31 PM
head light problem... viciousxp B13 91-94 chassis 1 Jun 16th, 2004 11:29 AM
tail light covers? Boromir Cosmetic Mods 11 Aug 26th, 2003 09:37 PM
You may post new threads
You may post replies
BB code is On
