Originally Posted by Uberdavey
Have a 95 200sx 1.6 manual. My car was driving fine, and I parked it, next day I went out to start it and no luck. The starter would turn, but it would not start. Jumped it to make sure it was getting enough power and no luck. Thought I might be able to push start it and pop the clutch like I did the last time I had a problem with the starter and it would not work. I recently (maybe 4 months ago) had my starter rebuilt, is it possible that the starter just went out again, or could it be something else?
If the motor is turnning over, I don't think it's the starter.
To run an engine needs: fuel, spark and compression. Make sure you are getting spark and fuel. Commpression is more then likley ok. Unless the motor is very old and abused.
If your getting spark and fuel I don't know mabey timming is way off.
Dave
