Old Jan 31st, 2005, 06:13 PM   #1 (permalink)
dfalcon02
Another car starting problem
Ok, this happened a month ago...I went on vacation for a week, came back, and my 97 Sentra(1.6L, auto) won't start. So I jump started it and everything's fine. I guess the battery didn't keep its charge for some reason. Went to autozone afterwards, and batt, alt, and starter all checked out fine. Fast forward to today. I started the car up, and it cuts off after 2 seconds. The car won't start afterwards, but it sounds like the battery has enough juice. The radio and lights work. I tried to jump start it, but it didn't help. I just got my alternator replaced about 6 weeks ago, and my starter works, so it sounds. There's just something keeping the car from starting all the way. I don't know what to do.
dfalcon02 is offline   Reply With Quote
Old Jan 31st, 2005, 10:39 PM   #2 (permalink)
Lemondrop
Does it spin over/crank ? If the engine is turning over then you lost ignition or fuel . Try to have someone crank the engine while you bang your hand on the bottom of the fuel tank . Sometimes that will get a bad fuel pump to kick off again , but it will stick again .
Just make sure the person cranking won't run you over if the engine starts
Lemondrop is offline   Reply With Quote
Freeze Starting Problem with GA16DE 1.6 georgyop GA16DE 1.6L Engine 8 Jan 11th, 2005 07:58 PM
engine not starting (just a story, not a problem..anymore) Tavel GA16DE 1.6L Engine 0 Jan 1st, 2005 11:28 PM
Please Help!!!!!!!! Starting Problem! L2daA GA16DE 1.6L Engine 5 Feb 21st, 2004 06:39 PM
95 Sentra starting problem. davmil GA16DE 1.6L Engine 6 Feb 12th, 2004 05:30 PM
problem when starting 97sentragxe B14 95-99 chassis 4 Apr 20th, 2003 01:20 PM
