Old Jan 28th, 2005, 04:38 PM   #1 (permalink)
Rathi134
Munga Wurm Follower
Rathi134's Avatar
Send a message via AIM to Rathi134
battery cutoff switch
well since the batter is in the trunk I have to have this for drag racing.
#1. anyone know of a site that shows me how to make one
#2. anyone have any ideas of how to mount it to the outside without cutting holes in the body. i would like it to be somewhat disconnectable so i dont have a battery cutoff switch located outside the car all the time. thanks
It's not a matter of deserving. It's a matter of strength. the power to hold versus the power to take.- Sygg, River Cutthroat
Rathi134 is offline   Reply With Quote
Old Jan 28th, 2005, 08:30 PM   #2 (permalink)
manuelga
Proud 2004 X-Trail Owner
manuelga's Avatar
IMHO Put it in the hood. (The battery)
If you want the car for drag, you need more weight at the traction axle, than at the slave one, just my 2 cents.
manuelga is offline   Reply With Quote
Old Jan 28th, 2005, 09:46 PM   #3 (permalink)
ReVerm
Boxed Fox
ReVerm's Avatar
What does the rulebook say about battery cutoff location? They might not let you put it under a crushable panel like the hood or trunk.
Captain Slow.
Old Jan 28th, 2005, 11:26 PM   #4 (permalink)
Ninety-Nine SE-L
Please Shift Here
Ninety-Nine SE-L's Avatar
Send a message via AIM to Ninety-Nine SE-L
A fuse right after the battery is important in a situation of shorting. When my last car was totaled, the fuse cut me right off:
Ninety-Nine SE-L is offline   Reply With Quote
Old Jan 29th, 2005, 07:19 AM   #5 (permalink)
Rathi134
Munga Wurm Follower
Rathi134's Avatar
battery is in the trunk because it does not fit under the hood anymore. If the battery is in the trunk you have to have the cutoff switch, it needs to be mounted on the back.
Old Jan 29th, 2005, 07:01 PM   #6 (permalink)
Ninety-Nine SE-L
Please Shift Here
You DEFINATELY need somethig to cut off the battery in case of emergency. Like I said, I prefer an in-line fuse rather than a cutoff switch, a fuse will react faster and on its own. If you are required to have a cutoff, go to an autozone or a car audio store and you will find one. Heck, I would recommend you do both fuse and cutoff.
BTW, be sure to use multiple grounds like I did, it makes it ALOT better.
Old Jan 31st, 2005, 04:48 PM   #7 (permalink)
wes
Wise Cracker
wes's Avatar
Send a message via AIM to wes
Is your local track official telling you this? All that should be required is that it be properly fused withiin 18 inches. If so then just get a circuit breaker and install it within 12 inches of the battery. It can act as a cutoff as well as a circuit breaker.
www.NissanPerformanceMag.com
JWT
www.notnser.com
Frontier Crew Cab Fog light wire harness Tan Frontier Truck & SUV 10 Jan 13th, 2008 02:50 PM
Wiring info for installing OEM power windows/locks in a '93 Sentra 4 door. toolapcfan B13 91-94 chassis 4 May 8th, 2005 03:15 AM
Battery dead, starter biffed? nemui_panda GA16DE 1.6L Engine 1 Aug 24th, 2004 08:05 AM
battery terminal cutoff switch samk B13 91-94 chassis 9 Jul 21st, 2003 03:32 PM
Recommended battery DNYC B11/B12/KN13 82-90 chassis 21 Feb 4th, 2003 09:37 PM
