Old Jan 27th, 2005, 01:15 PM   #1 (permalink)
clinton
need help w/lowering prblem
I have a 97 sentra which I lowered.I used weapon-r coilovers and kyb gr2 struts/shocks.The problem I'm having is when I turn the wheel I get a clanking noise coming from the springs.It is definitely the springs because you can see them binding when I turn the wheel.Also if I turn left after I straighten out the car it will pull left and same thing with the right.Someone told me that it is the strut mount and/or bearing.Does anybody know anything about this?If so i would appreciate any help
clinton is offline   Reply With Quote
Old Jan 27th, 2005, 01:37 PM   #2 (permalink)
BlazinSent
Send a message via AIM to BlazinSent
i dun think its ur springs, if anything its the strut, when i had helped one of my friends lower his eclipse we had a very similar problem, 1st we forgot the order the parts stacked up....so thats one possibility, 2nd possibility is to take the spring and strut off and see if the rubber stopper move from its position on the strut....and lastly, the main problem was the plastic cover for the strut wasn't put on, which caused the rubber stopper to move. ....
BlazinSent is offline   Reply With Quote
Old Jan 27th, 2005, 01:46 PM   #3 (permalink)
I'm tired of my usernamee
Soggy GloryHoler
I'm tired of my usernamee's Avatar
Send a message via MSN to I'm tired of my usernamee
i think it has to do with the cheap coilovers and struts. The GR-2 where not designed to be used in lowered vehicles due to the fact that it cannot maintain proper rebound and control characteristics with higher spring rates. Im sure the spring rates on the "coilivers" are probably unknown. Try switching to AGX's or Koni's. Also the sound it the springs are binding is that the rubber on the strut mounts might have come out of place. Take the stetup and double check to make sure it was put together properly. BTW this should be in Suspension forum.
Originally Posted by mzanubis
yeah yeah yeah, the important question is... can it reheat my burrito?
www.nissanpacific.com
I'm tired of my usernamee is offline   Reply With Quote
Old Jan 27th, 2005, 07:52 PM   #4 (permalink)
Nostrodomas
Im out of here!!!!!!!!!!
Its because you removed the pillow mounts on top of the old strut assembly. It is a bearing that help keep the spring from binding. I bet when you turn left your car pulls to the left, and when you turn right your car pulls to the right? You can either buy some pillow mounts from Tein, or somehow remove the spring perch off of the stock ones and use them with your coils.
Nostrodomas is offline   Reply With Quote
Old Jan 28th, 2005, 03:32 AM   #5 (permalink)
nizzan4u2nv
Nissan Addict
Sounds like an installation problem. Your car could have blown struts and it will still drive right, just will be shitty.
Did you follow this procedure? I did and it came out fine.
http://www.nissanperformancemag.com/...spension.shtml
B14/S14
nizzan4u2nv is offline   Reply With Quote
Old Jan 28th, 2005, 09:49 PM   #6 (permalink)
ReVerm
Boxed Fox
ReVerm's Avatar
Did you forget to put the strut bearings in? The OE Nissan one is a little black plastic disc which is pretty easy to lose/forget about.
Captain Slow.
Old Jan 28th, 2005, 09:57 PM   #7 (permalink)
esco2k2
esco2k2's Avatar
Send a message via MSN to esco2k2
It is the strut bearings. I had the same problem with my Tein Basics, and come to find out i forgot to put them on. Me= dumbass
97 BMW 328IS. Cosmos Racing CAI, Bosal Cat-back, Blacked out lights all around, Sparco strut brace, Brembo Slotted Rotors, B+G S3 Coilovers, Kmac camber plates and rear camber arms
esco2k2 is offline   Reply With Quote
Old Jan 29th, 2005, 03:22 PM   #8 (permalink)
Tony@performance
Send a message via AIM to Tony@performance Send a message via Yahoo to Tony@performance
It might be the top of the strut like everyone seems to be agree on. however, i wouldn't run those coilovers on that car, that's a problem in and of it'self. Ditch em, they are nothing but trouble.
Tony@performance is offline   Reply With Quote
NO clue to what the prblem is? RB26Maxima A32 1995-1999 Chassis 4 May 6th, 2004 07:57 PM
