I was driving my nissan 200sx ser hard today and the last place I shut it off. It would not crank again. Well I got it home and it will crank but it pours fuel smoke out of the exhaust!!! I pulled the plugs out and they were all fouled so I put new ones in and it will do the same thing. For some reason it is dumping too much fuel. I don't know if a sensor has gone bad or something internal that will be worse but any help would be greatly appreciated. The oil pressure is still fine and the oil color shows no sign of water. Maybe a burnt valve or jumped time....I am not too keen on these nissans. Any help please!!!!
Under further inspection I found that a white wire on the maf sensor has become disconnected and I reconnected it and bingo!!! It works again!!! Anyone having similar problems may want to check thier wiring.
