» Sponsors
» Sponsors
Go Back   Nissan Forums: Nissan Forum > Nissan Models > Sentra, Pulsar, NX, B14 200SX > B14 95-99 chassis
Old Jan 19th, 2005, 07:17 PM   #1 (permalink)
Imagesherd
Help please with power window problem
Hello my Nissan driving brothers and sisters,
I am have a problem with the power window switch on a 1999 sentra. The driver's window will go down, but will not go back up. I replaced the whole cluster and have the same problem. I traced the wires back to the wiring harness block and found the blue wire carries voltage for the "down" function, and a gree wire is supposed to show 12 volts in the "up" position, but it does not.
Could I have gotten a new switch with the same problem as the one I replaced...or is there something possibly wrong with the wiring that is causing the new switch to fry as soon as I install it?
Anyone have this problem? Any help would be appreciated.
Dave
Imagesherd is offline   Reply With Quote
Old Jan 19th, 2005, 10:00 PM   #2 (permalink)
Nostrodomas
Im out of here!!!!!!!!!!
Well where did you get the new switch?
Nostrodomas is offline   Reply With Quote
Old Jan 19th, 2005, 10:16 PM   #3 (permalink)
Imagesherd
At a junk yard I hate to say
Old Jan 19th, 2005, 10:20 PM   #4 (permalink)
Nostrodomas
The b14 drivers window switch is very prone to breaking. So yes you probably got another defective part. Try to return the part to the yard, and get one at the $tealership. They run around $90.
Old Jan 20th, 2005, 09:41 AM   #5 (permalink)
scooterbob
Send a message via MSN to scooterbob
It sounds more like a power window relay problem to me. If the wire going to the switch is not broke and shows no power coming to the switch when holding it in the up position, I would have to say the relay is a good culprit to consider. Worth a shot anyhow. Before spending 90 bucks on a switch I would go to the "junk yard" and try getting a cheap relay first. Good luck.
2008 Versa
scooterbob is offline   Reply With Quote
Old Jan 20th, 2005, 07:44 PM   #6 (permalink)
Nostrodomas
^^^ Another good idea to try.
Old Jan 20th, 2005, 07:47 PM   #7 (permalink)
Insert Name Here
Insert Name Here's Avatar
Send a message via AIM to Insert Name Here
I had the same problem and I went and got one from the junk yard too, and I got TWO deffective ones. they checked to see if they were the switches or if it was the motor and it was the switches. So yeah it can be the switches.
Try and see if u can raise the window using two wires and a battery, if it goes up then its the switches. All u have to do is touch the connectors that connect to the switches and it will either make it go up or go down.
:cheers:
Nissan Enthusiasts club starting in EPTX
Insert Name Here is offline   Reply With Quote
Stuck power window chacono Truck & SUV 3 Nov 1st, 2004 07:02 PM
aftermarket power window problem... fire_investigator Truck & SUV 0 Sep 22nd, 2003 08:26 PM
Rear Power window console Teknokid B14 95-99 chassis 3 Feb 19th, 2003 11:29 PM
Power window switch 200SXSE B14 95-99 chassis 9 Feb 11th, 2003 03:17 PM
power problem.... mpg9999 SR-Series Engines (DE/VE) 32 Dec 22nd, 2002 01:08 PM
