Old Dec 27th, 2004, 10:13 PM   #1 (permalink)
cf9
Unhappy HELP - headlight(s), brake light(s) not working
I've had my '96 Nissan Sentra for almost 9 years and have been its only owner. For the first time now I've run into this problem:
1) First my Left headlight (low beam) as well as my left brake light were not working. Being suspicious that both were the left (driver) side, I checked the fuses but they were okay. Also my Left high beam headlight worked fine.
2) Now my Right headlight (low beam) doesn't work as well. Also, NONE of the brake lights work (right, left and center). However, both Left and Right High beams still work fine.
I've read through some of the postings here and found some useful info. Except I'm still not sure -
1) Could it be all bulbs went bad all of a sudden?
2) Is the headlight switch gone bad?
3) Is there a relay/solenoid to check?
Any help/suggestions would be greatly appreciated - I really would like to look into this problem on my own before taking it to a dealer.
-CF
cf9 is offline   Reply With Quote
Old Dec 27th, 2004, 11:01 PM   #2 (permalink)
Nostrodomas
Im out of here!!!!!!!!!!
This happened to me also. I popped the hood, and taped the housing, and it flashed. So I grabbed the plug and wires, and pulled them up and held them there. The light stayed on. So I unplug the lights. Remove the bulbs, and inspected the plug. Over time the small metal contacts can spread apart. I took a small screw driver and pushed the contacts closer together. Plugged the bulb back in, and it was fixed.
Now hopefully this will fix your problem. If not you have bigger fish to fry.
Nostrodomas is offline   Reply With Quote
Old Dec 27th, 2004, 11:29 PM   #3 (permalink)
Token Moron
My ass, your face
Token Moron's Avatar
Send a message via AIM to Token Moron Send a message via MSN to Token Moron
take the bulb out and inspect it..u should be able to tell right away if it is bad. also, take a multimeter to the headlight harness and test the wires(there are only 3 wires anyway, with one being a ground u dont need to worry) see if there is any voltage coming through.
91 se-r : sr20det= the beast
96 sentra : ga16de= pimpness
00 frontier : ka24de= tow truck
01 sentra : gq18de= stock mofo
Token Moron is offline   Reply With Quote
Old Dec 27th, 2004, 11:31 PM   #4 (permalink)
Nostrodomas
Thats if my solution doesnt work 1st......
Damnitt A.J. quit following me...ahahahaha
Old Dec 27th, 2004, 11:33 PM   #5 (permalink)
Token Moron
My ass, your face
gotta correct all your ish foo!
Old Dec 27th, 2004, 11:36 PM   #6 (permalink)
Nostrodomas
Well see whos right..........
Probably neither of us.
CF9, just try bolth of our suggestions, one of them is bound to fix or find the problem.
Old Dec 27th, 2004, 11:44 PM   #7 (permalink)
Token Moron
My ass, your face
1. yes, could be
2. possibly, but not really possible because to use the high beams, the headlights must be engaged which leads me to believe that the switch is good.
3. no, just the 2 headlight fuses in the engine bay, but since the fuse controls both low and high beams, and the high beams work, the fuses would be good.
Old Dec 28th, 2004, 01:23 PM   #8 (permalink)
cf9
Thanks
Thank you Nostrodomas and Chops,
I thought for sure there was something centrally wrong for all the lights to stop working around the same time. But based on your suggestions, I finally managed to inspect all my bulbs in question and guess what?! ALL of them were bad! Actually it turns out that my rear stop lights were working and I was just not pressing the brake pedal hard enough last night before I posted my message.
So it turns out that my front headlights - both of them had broken filaments for the low beam and my left brake light had the same issue as well. I'm off to Advance Auto parts to get my bulbs (before it turns dark!) and will let you know how it goes.
Thanks again,
CF
Old Dec 29th, 2004, 09:50 AM   #9 (permalink)
cf9
Yup,
That's all that there was to it - just had to replace my 2 headlights (got a good deal at Advance Auto parts - and Sylvania has a rebate if you buy two qualifying bulbs). Also replaced my stop/tail light. Now everything's back to normal and it all cost me less than $20 - woo hoo!
-CF
No Speedo Working And Guage Lights Cyber240 S13 240SX 1989-1994 4 Nov 15th, 2004 11:57 AM
98 Altima backup lights not working zepman L30 1998-2001 Altima 4 Aug 4th, 2004 08:56 AM
tach working! only when lights off lol wtf Hans_Snarcher B13 91-94 chassis 7 Jul 27th, 2004 08:22 AM
Brake Lights? CivicKiller S13 240SX 1989-1994 5 Jun 2nd, 2004 12:46 PM
All red brake lights/ Crystal clear heads. Nostrodomas Cosmetic Mods 19 Jan 21st, 2003 08:09 PM
