First, i did search. i found few close to my problem but not sure if its similar. im gonna try to give more details.
i bought a set of clear corners cuz mine was broke (passenger side). and 25 bux for a set shipped isnt bad. they look good too,, after it stopped raining today i went and installed them. also installed new amber bulbs from advance auto. the problem is that my driver side turn signal dont blink on the front or back. it just stays on.. the passenger ones are fine. INSIDE the car. the cursor blinker blinks way too fast than normal when i put the left turn signal on..the right one is fine though.
i dont think water got on the wiring when i opened the hood. but i cant be completey sure, damn water can get anywhere.
what u people think? badly installed bulbs? bad relay? bad or water on wiring or socket?
had this problem on my buddys chevy truck today its either a bad bulb wich was his problem or a bad ground wire also since the break lights are on the same circuit get some one to hit the brakes and see if the light in the back comes on it shouldnt but if it does thats a bigger problem i belive just check all your bulbs take the ones from the right side and put them on the left and check them that way
when i hit the brakes they do light up. they dont blink on the driver side though. i tried many bulbs.. and yes ebay. the corners came with 2 bulbs and 2 screws. im going to mess with it tomorrow morning. what could be worse?
well, you could also remove both front corner lamp housings, completely, and switch them side to side to see if it's the sockets themselves. try to switch stuff side to side to isolate the problem better.
Heh, a goofy problem with mine is when I put the right turn signal on, the left headlight goes out, but I know what the problem is. It's the Light Multifunction switch that has worn with age, makes for interesting driving, espically for people behind me.
