Engine Sevice Soon Light after removing stock intake
ok, i removed my whole stock intake today, disconnected my MAI and AIT sensors, then i put it all together and know my car has the check engine soon light, and it kind of rattles a little bit. ANy suggestions?
Did you hook your sensors back up? Did you di it before or after you started your car? Auto zone will pull your codes for free. also you can try disconnecting your battery overnight and then hooking it back up the next day.
__________________ SE-R SpecV
Those who would give up Essential Liberty to purchase a little Temporary Safety, deserve neither Liberty nor Safety. - Ben Franklin
the thing is i hooked up the battery but forgot to hook up the MAI sensor back up, started the car twice, no good, then i saw that it wasn't hooked up, so without disconnecting the battery i hooked up the MAI. Did i fry that thing, or what?
Because you tried to start with out the MAF, thats what caused the error. It read that the sensor wasnt there or broke. Now that you have it plugged back in, you should be ok.
The code will turn off itself. It might take up to a month. It all depends on how many trips you take.
If you just cant wait that long go here: http://www.sentra.net/tech/ecu.php? , that site will show you have to manually clear the code yourself.
