Old Nov 28th, 2004, 04:54 PM   #1 (permalink)
roman4189
M-kay...
roman4189's Avatar
Remote Starter Problem
I just installed myself a remote started, Commando. I got the keyless part of it to work, but i can't start the car with the remote. I've pressed many buttons, and tryed programming it. Still doesn't work, any ideas what i might have missed. I understand i could have installed the wires wrong, but i think it's all good. It's just the programing it might be a problem. Any ideas?
Nissan Sentra 98 B14
http://www.cardomain.com/id/roman4189
roman4189 is offline   Reply With Quote
Old Nov 28th, 2004, 05:01 PM   #2 (permalink)
Modemagic
Send a message via AIM to Modemagic
get with the install/owners manual and see what it is your supposed to be doing to start the remote start process. I'm not familiar with the Commando units.
Is your tach programmed? Not all but the mass majority require you to program a tach into the remote start.
Hood pin?? Is the hoodpin connected and up? (Showing ground to the unit)
Give those things a try and let us know!
Thanks,
Dave
'92 Nissan Sentra GXE - 198k and counting
Modemagic is offline   Reply With Quote
Old Nov 28th, 2004, 05:03 PM   #3 (permalink)
MagicPie
Now w/20% More Magic
MagicPie's Avatar
If you can hear the relays in the control box clicking over then you must have the wiring wrong,
but if the control box relays arent clicking over then likely theres a wire that when it is grounded it will prevent the starter from working this are usally connected to a switch for the hood, often people dont install the hood opening disable switch and try just connecting the wire to ground when in fact it should not be grounded
96 200sx with Erebuni 285 kit (GTR), 17" OZ superleggras, wilwood 4 pot 11" brakes, rear disc conversion ,lots suspension upgrades, hotshot header, stromung exhaust, CAI, UR pulley, JWT cams and ecu, racing seats, new carpet and rear seats a few other cosmetics sold car for 350Z
MagicPie is offline   Reply With Quote
Old Nov 28th, 2004, 05:58 PM   #4 (permalink)
Modemagic
I grabbed the wirecolors straight off of DEI's website for ya
1998 Nissan Sentra
12volts white/red + ignition harness
Starter black/yellow + ignition harness
Second Starter black/blue + ignition harness
Ignition black/white + ignition harness
Accessory blue & blk/pnk + ignition harness
Power Lock gray - white harness in driver kick
Power Unlock purple/silver dots - white harness in driver kick
Parking Lights+ red/blue conn. above fusebox
Door Trigger red/white - driver kick panel
Trunk/Hatch Pin red/silver dots - sw. or light in trunk
Factory Alarm Arm lt.green/red - drivers kick
Factory Alarm Disarm green/yellow - drivers kick
Tachometer green AC coil, instrument panel
Brake Wire red/green + brake pedal switch
Horn Trigger brown to green/yellow - steering column
Thanks,
Dave
Old Nov 28th, 2004, 07:49 PM   #5 (permalink)
roman4189
M-kay...
roman4189's Avatar
thanks, but i know have a bigger problem. My car doesn't want to start. I thought it was the battery, changed it, still didn't work. Then took of what i did with the remote starter, STILL didn't work. I might think it's the spark plugs. I took two out, there is a spark, but they were covered with fuel.
Old Nov 28th, 2004, 08:56 PM   #6 (permalink)
Modemagic
Sounds like it... get that motor fixed then u can continue with the remote start install
Thanks,
Dave
Old Nov 28th, 2004, 11:15 PM   #7 (permalink)
iceman
Send a message via AIM to iceman
i know this is probably too late, but with my old bulldog remote starter that i installed myself (should've paid for someone else to do it) i needed another little box that had to overide a security system issue. you may want to check into that.
iceman is offline   Reply With Quote
Old Nov 29th, 2004, 06:15 AM   #8 (permalink)
roman4189
M-kay...
roman4189's Avatar
i don't have any security on my car, that i'm aware of atleast.
Old Nov 30th, 2004, 11:53 AM   #9 (permalink)
jer28
Nissan Fanatic
Most nissan's require you to use a relay to obtain the second ignition wire. Go buy a standard relay and tap off of the primary ignition wire.
In my case I only had one starter wire but my installation was on another make of car. It looks like the list for this car contains two. Find out if you need a second ignition wire and let us know if you have one connected or not.
jer28 is offline   Reply With Quote
Old Dec 4th, 2004, 11:17 PM   #10 (permalink)
roman4189
M-kay...
roman4189's Avatar
i think i need something that will overide the security on the car, but i don't know where to get it or anything
Old Dec 5th, 2004, 10:52 AM   #11 (permalink)
jer28
Nissan Fanatic
It looks like you don't have any security. Do you have a factory keyless entry system, if so then I think that they incorporate the security with the keyless system. I have a GXE with power stuff but with no keyless entry system.
If you do have a factory alarm system then it needs to be overridden during the remote start process. The remote starter has an output (positive or negative). What you need to do is determine if you have a negative or positive alarm trigger first. Most cars have a negative disarm trigger. Here's how to find the trigger wire (negative trigger)- probe the suspected wire (my starter gave me the color off their website) with one of the meter leads then put one lead of the multimeter on the positive battery terminal, now put the key in the drivers side door and hold the key at the unlock position, you should have 12 volts.
Once you did that and found the correct wire connect it to the wire for the remote starter factory alarm disarm wire. The starter will now disarm the factory alarm system ONLY during the remote start process. If you have all the other connections correct then your starter should work now. Did you find out if your vehicle requires 1 or 2 ignition wires yet? If you only have one ignition wire hooked up the remote starter will never work. I have a feeling that this is your problem, not the alarm.
Old Dec 5th, 2004, 10:58 AM   #12 (permalink)
roman4189
M-kay...
roman4189's Avatar
there is only one ignition wire, and i have one wire hooked up to it from the remote starter unit. Do i need two wires from the unit to be hooked up to the one ignition wire or what?
Old Dec 5th, 2004, 02:06 PM   #13 (permalink)
jer28
Nissan Fanatic
Yes, most nissans have 1 ignition wire, as you point out. Does your remote start have 2 ignition wires? My remote starter had 2 ignition wires, I think most units do.
If your remote starter requires 2 ignition wires you will need to buy a standard 12 volt 30 amp relay (advanced auto part number 84601 conduct tite about 8 dollars). ground out terminals 86 and 30. hook up a jumper from your one ignition wire that you have hooked up currently and connect it to terminal number 85. Now the second ignition wire needed from the remote start unit will connect to 87.
Old Oct 10th, 2005, 09:21 AM   #14 (permalink)
Federal1998
Unhappy 2001 Pathfinder
I need help with the vehicle wiring to install a Commando Remote Starter. The wiring diagram that I've downloaded for the vehicle was insufficient. Has anyone install the Commando on their vehicle?
Please help!
Thank you.
Federal1998 is offline   Reply With Quote
Shifting problem blazebridge U13 1993-1997 Altima 5 Jun 23rd, 2004 11:25 AM
Starter Motor Problem... beethaniel SR-Series Engines (DE/VE) 6 Apr 24th, 2004 02:59 PM
car starter?? fondoo B14 95-99 chassis 1 Nov 3rd, 2003 01:29 AM
Engine idle freaked out, went right back to normal sfhellwig GA16DE 1.6L Engine 27 Oct 24th, 2003 01:40 PM
starter problem? roffclem B14 95-99 chassis 4 Sep 2nd, 2002 01:18 AM
