Old Sep 26th, 2004, 08:32 PM   #1 (permalink)
ILoveToreadBooks
ILoveToreadBooks's Avatar
Unhappy REAR BRAKES!
How do I know when to replace the REAR BRAKES?
ILoveToreadBooks is offline   Reply With Quote
Old Sep 26th, 2004, 08:36 PM   #2 (permalink)
Radioaktiv
even better the 2nd time
Radioaktiv's Avatar
drums or discs?
champagne taste on a beer budget
Radioaktiv is offline   Reply With Quote
Old Sep 26th, 2004, 08:59 PM   #3 (permalink)
ILoveToreadBooks
WELL THE FRONT BRAKES ARE DISCS. SO I GUESS THE REAR BRAKES ARE Discs.
Old Sep 26th, 2004, 09:05 PM   #4 (permalink)
aminidab
Destroyer of Engines
aminidab's Avatar
That is a poor assumption.
96 Sentra GXE
Boost is addictive
265WHP/257WTQ
aminidab is offline   Reply With Quote
Old Sep 26th, 2004, 10:22 PM   #5 (permalink)
Tavel
Destroyer of worlds.
Tavel's Avatar
Send a message via AIM to Tavel
very poor indeed, the only sentra i know of that has 4 wheel disc stock is a b13 se-r...my girlfriends b14(what you have) has disc front and DRUM rear. most economy cars have disc front(for safety) and drum rear(for cost cutting).
basically when the brakes start making noise when the brakes are applied is a good time to change them. and if you've never done drum brakes then go buy a haynes manual, they're pretty cheap and you'll be absolutly lost without one.
i have a question though. how come when you replace the brake pads/shoes the brakes seem to lose their effectiveness...like the pedal goes down further before anything happens, whats up with this?
I'll edit YOUR signiture!
Tavel is offline   Reply With Quote
Old Sep 26th, 2004, 10:30 PM   #6 (permalink)
OmegaManEX
Work With What You Got
OmegaManEX's Avatar
Send a message via AIM to OmegaManEX
B13 : SE-R = Disc/Disc E/XE/GXE/SE = Disc/Drum
B14 : SE-R/SE/SE-L = Disc/Disc E/XE/GXE/SE = Disc/Drum
excessive vibration , fade , and more pedal effort are situation for a brake inspection.
B14 200sx: GA16DE at 15º BTDC + HS CAI + stromung cat-back + UR crank pulley + JWT S1 Cams
Cosmetics: SE-R wheels & skirts + Stillen Lip + CrystalClear Headlights & Corners + 98 Sentra Grill
Suspension: Tein Basic's + Front & Rear Strut Bar
OmegaManEX is offline   Reply With Quote
Old Sep 26th, 2004, 10:38 PM   #7 (permalink)
ILoveToreadBooks
Thumbs up
OMEGA, I have DRUM BRAKES IN THE REAR. How do I know if they need to be replaced? Would I have to do the test in REVERSE?
P.S. I replaced my front brakes today. Replacing Front Brakes is a piece of cake if you ask me.
Old Sep 26th, 2004, 10:50 PM   #8 (permalink)
lshadoff
Post Freak
lshadoff's Avatar
Take off the rear wheels and brake drums. Examine the brake shoes. The lining wear limit is 1.5mm (0.059 in) according to the Factory Service Manual.
Lew
lshadoff is offline   Reply With Quote
Old Sep 26th, 2004, 11:26 PM   #9 (permalink)
ILoveToreadBooks
Lightbulb
How do I take off the Brake Drums? I have the tools
Old Sep 26th, 2004, 11:45 PM   #10 (permalink)
lshadoff
Post Freak
lshadoff's Avatar
Take off the rear wheel. Release the parking brake. To remove the rear drum you just slide the drum off. Grab it at opposite ends and pull/rock, then move your grip and do it again. It should start to move and finally slide off.
If it is hard to remove, you back off the adjuster, screw 2 bolts in the threaded holes in the drum and turn them to drive the drum off.
Lew
Old Sep 27th, 2004, 07:29 PM   #11 (permalink)
Tavel
Tavel's Avatar
dont forget to take off the wheel bearing/hub. it will be almost impossible to put the brakes back together with that stuff in your way.
Old Sep 27th, 2004, 09:48 PM   #12 (permalink)
lshadoff
Post Freak
lshadoff's Avatar
That is not the procedure in the Factory Service Manual. It indicates to remove the drum. Then remove the brake shoe retainer followed by the spring by rotating the shoes. Then remove the adjuster and parking brake cable. Once the shoes are removed, remove the retainer holding the toggle lever to the brake shoe and separate the parts.
Assembly is the reverse of removal. Apply grease to the places the brake shoes contact the backing plate before assembly. Also, shorten the adjuster by turning it so there is room for the new, thicker brake shoes.
Lew
Old Sep 28th, 2004, 07:40 AM   #13 (permalink)
Tavel
Tavel's Avatar
Lew
go and do it for yourself, you'll see.
Last edited by Tavel : Sep 28th, 2004 at 08:05 AM. Reason: first response was very rude
Old Sep 28th, 2004, 10:23 PM   #14 (permalink)
ILoveToreadBooks
My rear brakes need to be clean and adjusted. Thats what the guy at Mr.Tire told me. By the way my rear brake shoe pads are in good condtion. I need to pratice alot before I replace the rear brakes myself, because it just looks so complicated.
Old Sep 28th, 2004, 10:34 PM   #15 (permalink)
Tavel
Tavel's Avatar
well its really not that hard, as long as you have a diagram/picture next to you or you mirror the other side...its a piece of cake.
hell my girlfriend can do it, except shes not strong enough to pull the springs, thats where i come in lol. but we did it on our own without any prior experience just by comparing the side we were working on to the untouched side. its really not hard at all.
(and removing the wheel hub! lol )
2001 Sentra rear brakes adjustment? bonestocksentra Suspension & Brakes 8 Aug 11th, 2004 04:34 PM
3rd Gen Maxima Rear Disc Brakes!!! maxima_stallion J30 1989-1994 Chassis 2 Apr 21st, 2004 10:07 PM
Just looking.. and i think i have found something interesting for the B14 rear brakes Chuck Suspension & Brakes 4 Jan 14th, 2004 08:39 AM
Rear brakes locked up, help! Attrayant Z31 300ZX(T) 2 Sep 22nd, 2003 09:20 PM
front brakes in rear? 2k2xsexima Suspension & Brakes 2 Jun 29th, 2003 12:01 AM
