Old Sep 22nd, 2004, 05:12 PM   #1 (permalink)
98Sentra
Horn beeps itself! Air bag connector interfering ?
Hope someone has a quick answer for this. The horn on my 98 sentra beeps when I hit the smallest of bumps! The problem appears to be in the steering column because if I move it up or down the horn will beep.
All you have to do is jar the car and the horn goes off.. Any ideas?
And how do you get between the Air bag and the plastic cover over the wheel?
There is a yellow connector in the steering column. When I move it the horn sounds. Has anyone had this problem?
98Sentra is offline   Reply With Quote
Old Sep 22nd, 2004, 05:31 PM   #2 (permalink)
Radioaktiv
even better the 2nd time
Radioaktiv's Avatar
sounds like the wire/connector that completes the circuit for the horn is loose
champagne taste on a beer budget
Radioaktiv is offline   Reply With Quote
Old Sep 22nd, 2004, 06:08 PM   #3 (permalink)
98Sentra
Is is something behind a yellow connector (air bag?) on the bottom Right side (passenger) of the steering column. Near the wheel not in the column itself. There appears to be a wire stuck under a plastic disc of some sort.
When I move the yellow connector the horn goes off. When I push the wires that pass under this yellow connector the horn will stop. When the connector is pushed again the horn sticks on. Moving the connector "appears" to move the clear plastic disc.
Now I just have to figgure out how to remove the yellow thing without breaking it! Hopefully I will find a lose/broken wire under there.
Old Sep 22nd, 2004, 08:28 PM   #4 (permalink)
Radioaktiv
Radioaktiv's Avatar
that could very well be your problem
id check this out thoroughly, since you say by messing with the wire you can make the horn come on or off
its kinda hard to diag over the forums, without pics or without actually being there
Old Sep 22nd, 2004, 09:52 PM   #5 (permalink)
98Sentra
Well I had to put it back togehter unfixed.
Cant remove the yellow connector.
Back to the library and Haynes books tomarrow!
Old Sep 29th, 2004, 01:35 AM   #6 (permalink)
Jim98SE-R
99-050A 991001 Horn - Activates by Itself
Nissan has a Technical Bulletin (99-050A 991001 Horn - Activates by Itself ) that covers this. The fix mentions replacing the springs that make contact between the the steering wheel base and the part you actually push on to sound the horn. Unfortunately, this requires removal of the airbag. This is a procedure best left to a professional or at least someone who really knows what's going on. ( I am NOT suggesting you don't!) The bulletin lists a flatrate time of only .3 hours to do the job so it shouldn't be too expensive.
BTW, I think the yellow connector is for the airbag -- please don't try to disconnect it.
Jim98SE-R is offline   Reply With Quote
Old Sep 29th, 2004, 02:13 PM   #7 (permalink)
ltcassio
Complete Loser
Send a message via AIM to ltcassio Send a message via Yahoo to ltcassio
^^^^ yeah, be extra careful removing an airbag. had a friend with a del sol who earned himself a night in the hospital fucking with his...
1998 Sentra SE
JL Audio VR650-CXi's and TR-650-CSi's out of an Alpine CDA 9827 Headunit, more to come soon.
Oh and some strut bars and stuff... I need more money.
ltcassio is offline   Reply With Quote
Steering Mod dreadsword B13 91-94 chassis 8 Jan 28th, 2003 05:14 PM
HELP...power steering conversion sunnyb11 B11/B12/KN13 82-90 chassis 1 Jan 19th, 2003 12:16 PM
removing the steering rack (not column) JonHasAn89SE B11/B12/KN13 82-90 chassis 8 Sep 21st, 2002 11:27 PM
smoke from steering column? frznwater B14 95-99 chassis 4 Aug 13th, 2002 01:27 AM
Steering needs to be tighter? Sethticlees B13 91-94 chassis 6 Jun 5th, 2002 10:28 AM
