Old Sep 19th, 2004, 02:02 PM   #1 (permalink)
netsatwork
After HS CAI, won't stay running. HELP!
I finally got my HS CAI installed today. I'm still having trouble getting the lowest sensor installed into the piping (the grommet and hole are too small for the sensor and I had to lengthen the sensor wires). Now when I start the car it will go to 1500 then drop immediately to 1000 and then die. It runs for about 3 or 4 seconds then just dies. It's similar to if there was no gas getting to it. All I've done is put the CAI on. PLEASE give any help you can.
1999 Sentra SE-L
netsatwork is offline   Reply With Quote
Old Sep 19th, 2004, 02:09 PM   #2 (permalink)
SleepERr
SleepERr's Avatar
Send a message via AIM to SleepERr Send a message via Yahoo to SleepERr
did you check your maf? you could have it on backwards (this happened to a friend on his spec). there is a little arrow on it that should point in the direction of the flow. my car seems to run fine with out the ambient temp sensor.
93 s13..stock.....RB25?
SleepERr is offline   Reply With Quote
Old Sep 19th, 2004, 02:35 PM   #3 (permalink)
netsatwork
Thanks. That was exactly it. I feel like an idiot, but at least the car works. Thanks again.
1999 Sentra SE-L
Old Sep 19th, 2004, 02:35 PM   #4 (permalink)
Nostrodomas
Im out of here!!!!!!!!!!
Or make sure it is still plugged in.
Nostrodomas is offline   Reply With Quote
Old Sep 19th, 2004, 02:39 PM   #5 (permalink)
lshadoff
Post Freak
lshadoff's Avatar
The IAT sensor is not used to control the engine, it is used for diagnostic purposes, so dsconnecting it will not affect the way the engine runs. However, it will trip a MIL light if it s disconnected.
Lew
lshadoff is offline   Reply With Quote
Old Sep 19th, 2004, 04:14 PM   #6 (permalink)
netsatwork
I got all of the sensors plugged back in and everything is running. I love the sound it makes. There's a nice growl in 2nd. I have to punch it pretty good to get the full sound. Intially, I don't feel much difference in the power. I am getting an engine light and need to reset the ECU. Perhaps I'll feel a little more after that? I know I can't expect anything amazing from a CAI, but I thought I'd feel something. Perhaps I'll notice more tomorrow after I drive it around a bit more. Thanks for your help.
1999 Sentra SE-L
Old Sep 19th, 2004, 04:21 PM   #7 (permalink)
Nostrodomas
You arent going to feel much until you open up your exhaust, I.E. cat back, or header.
Old Sep 19th, 2004, 05:09 PM   #8 (permalink)
Token Moron
My ass, your face
Token Moron's Avatar
Send a message via AIM to Token Moron Send a message via MSN to Token Moron
u wont feel much bottom end, u will feel midrange and top end increase a bit.
91 se-r : sr20det= the beast
96 sentra : ga16de= pimpness
00 frontier : ka24de= tow truck
01 sentra : gq18de= stock mofo
Token Moron is offline   Reply With Quote
Old Sep 19th, 2004, 05:22 PM   #9 (permalink)
netsatwork
Yeah, hopefully around Christmas time I'll be able to look into a HS header and some type of cat-back. I'm thinking I may invest in Tein coilovers first. We'll see.
1999 Sentra SE-L
probs with cai and water johnp69 B15 2000-2006 9 Sep 10th, 2004 10:40 PM
HS CAI for $200 free shipping!? cmalec1224 GA16DE 1.6L Engine 10 Apr 15th, 2004 07:14 PM
HS CAI and AEM BYPASS VALVE FatBoy4 B14 95-99 chassis 8 Mar 5th, 2003 11:31 PM
Dip stick doesn't stay while running WhiteFox E/CA-Series & GA16i Engines 4 Jan 31st, 2003 04:15 PM
My Car Won't Stay Running! 91SR20DE B13 91-94 chassis 12 Dec 15th, 2002 01:30 AM
