I had the same problem. It rained in my car and the master switch (box of buttons in the drivers door that controls windows and door lock) shorted out. For a while my power locks would work every now and then, and the tail lights and dashboard lights wouldn't work because the fuse kept blowing. I got a new master switch control thing from the dealership for $96 plus tax, and the problem was solved. You can test to see if that's where the short is by disconnecting the switch (just take the one screw out of the little door handle thing, then pull it out and you can see the connector), replacing the fuse, and seeing if your lights work with the window controls disconnected. If they work, you know where the problem is, and then your only problem is finding $100 or a junkyard. Good luck,
Steven
