» Sponsors
» Sponsors
Go Back   Nissan Forums: Nissan Forum > Nissan Models > Sentra, Pulsar, NX, B14 200SX > B14 95-99 chassis
Old May 21st, 2002, 02:02 PM   #1 (permalink)
fondoo's Avatar
Send a message via ICQ to fondoo
Check Engine Soon Light?
I've gotten a Injen Cold air intake installed on my nissan sentra by a local autosports shop and now i have this check engine soon light on my dashboard. the people at the autosports shop claim that the check engine soon light kicked in when he removed the battery from the car to install the cold air intake and the light will go away after couple of start up's. is this true and is there another way of turning it off?? these ppl at the autosports shop are starting to piss me off.
fondoo is offline   Reply With Quote
Old May 21st, 2002, 02:11 PM   #2 (permalink)
in^3,N20,RPM,PSI
James's Avatar
Re: Check Engine Soon Light?
no the light won't go away. reset the ecu and find out what code it is. more than likely it's the MAF (12) since you got an intake they probably forgot to connect it and turned it on and reconnected it afterwards.
Old May 21st, 2002, 09:27 PM   #3 (permalink)
tiffany was hardcore?
Talking
same thing happened when i put in my hotshot . as long as the mass air is still attached it is just trying to get a feel for the new placement of it the air is coming in at a different plac take it to any good mechanic they should be able to reset the let and/or see if there is a problem sometimes performance shop guiy forget to re attach the air sensor from the stock air box ( different from mass air it is a little plug)
:cheers: 96 S14.5 in the works needed some much needed love but we are almost there!!!! kind of miss my b14 though :fluffy:
dont you just love fluffy
addictednissan is offline   Reply With Quote
Old May 22nd, 2002, 09:33 AM   #4 (permalink)
in^3,N20,RPM,PSI
James's Avatar
do it yourself. all you need is a 12mm socket and a screwdriver. takes like 5 min and you can tell what is wrong with your car.
not sure where this goes...check engine light? Tickwomp Off Topic 4 Jun 11th, 2003 03:41 AM
check engine light Redrocket B14 95-99 chassis 8 May 7th, 2003 08:32 AM
having trouble with my engine check light palengkeboy S13 240SX 1989-1994 4 Feb 5th, 2003 03:39 PM
check engine light & emissions nismofreak GA16DE 1.6L Engine 5 Jan 21st, 2003 11:15 PM
check engine light drpepper911 B14 95-99 chassis 14 Jun 19th, 2002 12:57 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
