can anyone give me some feedback on how an cold air intake works? how does it increase your horsepower? i cant find any information on it. all i can find is people selling them.
Originally posted by fondoo can anyone give me some feedback on how an cold air intake works? how does it increase your horsepower? i cant find any information on it. all i can find is people selling them.
Cold air is denser hence it can produce more power due to more o2 in it per given volume.
The best of the CAI's like AEM are tuned in length to resonate at a given RPM and use that effect to increase power as well.
The extension relocates the filter away from the engine bay away from the heat and in to the bumper. The air is always cooler there and at speed is readily availible. I dont know if you have noticed how hot the sentra and 200 engine bay gets but if you ever hit traffic in the rain you will see what i mean, steam just rises right off the hood. With about 65$ you can make one that is just as good as some of the ones selling. All you need is a 3" 90 deg. manderal bent U pipe. Some 2* 3" inch rubber sleaves and 4*hose clamps. 1*3/4" rubber plug opening. and a saw and a drill. You take and slide the battery tword the engine as far as you can twords the engine in the tray. Cut the U bend in half at the center of the raidiuse connect it to the mass air opening with the rubber sleave and mark where you want the hole to drop down the rest of the extension and filter. It should be right arround the back Right hand side of the batterey. There is already the stock airbox hole that is there that is small. you can either cutt a hole out or bend the edges down to open it up. Take the bumper of and measure the length and cutt the rest of the U pipe to length. Tesfit everthin and measure twice. Now for the o2 sensor u will need to find a spot on the bottom of the 3" extension that is close to the sensor (should be right at the start of the bend before the pipeing drops into the fender. Dill your hole 1/2" put the plug in and slide the sensor into place. Clamp everything down and you are ready to go... I actully had mine painted to match the car and through a NISMO sticker on it to dress it up.. i will see if i can dig up a pic....
Originally posted by syndicate-bro I dont know if you have noticed how hot the sentra and 200 engine bay gets but if you ever hit traffic in the rain you will see what i mean, steam just rises right off the hood.
we haven't been getting that much rain down here in CA...
Originally posted by psteng19 My question is WHY does the intake make the noise it makes?
well because the resonance in the big metal tube, it's like a big instrument... also because the holes in the filter make the air 'vibrate' b/c of the resistance, it's like the old blowing into the top of a bottle effect... except a lot higher pitch. not that noticeable tho.
on the top of the throttle body there is a black plastic cap. pop that cap off and you can use a screwdriver to adjust the air flow to minimalize the hissing sound, it takes some tinkering to find out how your car will like the adjustment. Some cars idles will bounce. you need to find the happy medium, the hissing will not completely go away because the filter is alowing alot more air throung and it isnt confined in an air box..
adjusting, the idle screw has a drawback. I turned it down and the hissing went away, but as a result, the point where the hissing stops, the idle is so low, that the car stalls whan I come to a stop. I eventually had to turn it back, to keep the engine running normally.
Originally posted by syndicate-bro The extension relocates the filter away from the engine bay away from the heat and in to the bumper. The air is always cooler there and at speed is readily availible. I dont know if you have noticed how hot the sentra and 200 engine bay gets but if you ever hit traffic in the rain you will see what i mean, steam just rises right off the hood. With about 65$ you can make one that is just as good as some of the ones selling. All you need is a 3" 90 deg. manderal bent U pipe. Some 2* 3" inch rubber sleaves and 4*hose clamps. 1*3/4" rubber plug opening. and a saw and a drill. You take and slide the battery tword the engine as far as you can twords the engine in the tray. Cut the U bend in half at the center of the raidiuse connect it to the mass air opening with the rubber sleave and mark where you want the hole to drop down the rest of the extension and filter. It should be right arround the back Right hand side of the batterey. There is already the stock airbox hole that is there that is small. you can either cutt a hole out or bend the edges down to open it up. Take the bumper of and measure the length and cutt the rest of the U pipe to length. Tesfit everthin and measure twice. Now for the o2 sensor u will need to find a spot on the bottom of the 3" extension that is close to the sensor (should be right at the start of the bend before the pipeing drops into the fender. Dill your hole 1/2" put the plug in and slide the sensor into place. Clamp everything down and you are ready to go... I actully had mine painted to match the car and through a NISMO sticker on it to dress it up.. i will see if i can dig up a pic....
Do you any pictures of the set up you built?
"A man is as faithful as his options" -Chris Rock
