Idle Problems - Nissan Forum
post #1 of 16 Old Jun 17th, 2004, 06:36 PM Thread Starter
Question Idle Problems
I have a 1997 Nissan Sentra, Just recently when I slow don or stop with the AC on the engine cuts off. In addition if i'm at idle the engine will cut off. If I turn the AC off the engine runs fine. Does anyone know what could be causing this? Thanks Wenwind
wenwind is offline
post #2 of 16 Old Jun 18th, 2004, 10:37 PM
Cone Dodger
azkicker0027's Avatar
Send a message via AIM to azkicker0027
so you're saying that the car stalls with the AC on?? common cause is a faulty idle air control valve. does the rpm dip very low when coming to a stop, then die??
Naturally aspirated autocross car.............naturally.
Retired STF champ car.
azkicker0027 is offline
post #3 of 16 Old Jun 20th, 2004, 08:53 PM
yeah, it doeson mine too.
bryan
-1995 Nissan 200SX SE-R-
Ractive Air filter, 2.5" Megan Racing cat-back exhaust system, "Custom" short shifter.
BryanC 95SE-R is offline
post #4 of 16 Old Jun 21st, 2004, 12:13 PM
It's probably the Air Regulator which is below the IACV. It's a square with two adaptors for hoses on each side, with the square part in the middle. I am pretty sure that the Air Regulator controls (raises) the idle when the AC or other heavy loads are on.
webninja is offline
post #5 of 16 Old Jun 26th, 2004, 08:34 AM
use wd 40
this was told to me by a nissan engineer not a mechanic but an engineer
there is a sensor on the throttle body held by two scews if you are in front of the car it is right in the middle the screws are facing the firewall
it is right on top on the TB close to the plastic intake
anyways take it out unplug the harness that it is attached to then just use wd 40 on it , i usually wd 40 the hole too
dry it up then put it back idle should be good as new
been doing it a while and it works...i've done it 4-5 times already
car has 189k miles
payk is offline
post #6 of 16 Old Jun 26th, 2004, 10:30 PM
Mofo
I had the same problem a few years back. I cleaned the IAC valve, and the problem was gone. Still no problems to date.
This is the IAC valve in Red:
Nostrodomas is offline
post #7 of 16 Old Jul 16th, 2004, 08:30 AM
jeffdano's Avatar
Yes, it is 99% likely to be the IAC, this was recommended to me a few months ago (believe I owe thanks to Nostrodomas). You could, if you have the patience, do it yourself, very easy to do with some carb cleaner and a lint-free rag. Haven't had a stall out or issue with AC all summer... thank God because I'm in the freakin' desert!
-jeffdano
jeffdano is offline
post #8 of 16 Old Jul 16th, 2004, 08:09 PM
Mofo
Good to hear it fixed your problem Jeff...
post #9 of 16 Old Jul 19th, 2004, 04:51 PM
I had this same thing happen to me and I had to replace the idle control valve...
96sentraGL is offline
post #10 of 16 Old Aug 24th, 2004, 10:33 PM
I have a 1996 sentra with 90 k in mileage.
Over the past couple of months i have noticed an extremely rough idle on cold starts. Once the car is running it is fine as well as starting after it is warmed up.
I plan on replacing the fuel filter this week, is this a sign of an O2 sesor on its way out?
What else might cause this? Plugs and wires were just replaced..
Thanks for your help
pksjay is offline
post #11 of 16 Old Aug 24th, 2004, 11:56 PM
Mofo
-jeffdano
post #12 of 16 Old Aug 25th, 2004, 09:24 PM
The iac is the thing covered in the black plastic correct? When i unbolt that is it going to fly apart or is it fairly easy to take off and then put back on?
pksjay is offline
post #13 of 16 Old Aug 26th, 2004, 07:15 PM
Mofo
Yes, all you need to do is unplug the sensor. Then take a large phillips screwdriver, and remove the two screws that thread into the throttle body. Nothing is going to fall apart. You do want to go easy on the gasket, if your gentle enough you can reuse it.
Once you get it off, the sensor looks like two cylinders, one inside of each other. The outer one turns, to reveal an opening in the two cylinders. What you want to do is, get some thinner, or gas, brakeclean, and clean the two cylinders. Especially where the slot is made when turning the outer cylinder. Damnitt im getting tired of typing cylinder........lol
post #14 of 16 Old Aug 26th, 2004, 09:51 PM
Ill give that a try next. I just replaced the O2 sensor, PCV, Plugs, Wires, Dist cap, and Battery. Good old refresher so we shall see.
pksjay is offline
post #15 of 16 Old Aug 27th, 2004, 12:33 PM
pcv valve.. ground wire.. fuel pressure check
You can try to replace your pcv valve.. check ground wires.. and also check fuel pressure... and fuel filter
thisisjh is offline
  Nissan Forum > Sentra, Pulsar, NX, B14 200SX > B14 95-99 chassis
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Linear Mode Linear Mode
idle problems tdee Truck & SUV 4 May 27th, 2008 05:18 PM
87 Kingcab with idle problems & introduction Warped Truck & SUV 4 Sep 10th, 2004 06:23 AM
TPS location and idle problems Jaralaccs GA16DE 1.6L Engine 1 Jun 8th, 2004 10:40 AM
idle problems.. L0sT S13 240SX 1989-1994 1 Apr 1st, 2003 08:31 AM
More idle problems ( 90 Sentra) Tom F GA16DE 1.6L Engine 0 Jul 14th, 2002 08:36 PM
You may post new threads
You may post replies
BB code is On
