How Much Transmission Fluid? - Nissan Forum
post #1 of 10 Old Jun 16th, 2004, 11:28 PM Thread Starter
m_seats's Avatar
Send a message via AIM to m_seats
I just emptied out my transmission fluid. Does any know how much im am supposed to put back in according to the fsm? I think its 7 3/8 quarts but i just want to be for certain.
Thanks
95 Sentra GXE: 17" Rota Sub Zero Rims, Falken Tires, Black Halo Projector Headlights, Black Stealth Crystal Clear Corners, Chrome Altezza Taillights, 4" Magnaflow Race Series Exhuast, Bomz Racing Air Intake, NGK Ignition Wires, Reverse Euro Glow Gauges, Front and Rear Strut Bars, Advanced Timing to 15 degrees, JL Audio Subs, Rockford Fasgate Amp
m_seats is offline
post #2 of 10 Old Jun 16th, 2004, 11:47 PM
...hmm i was wondering the same thing...what kind of transmission fluid would you use?? The stuff from the dealer??
aznSILVIA06 is offline
post #3 of 10 Old Jun 16th, 2004, 11:48 PM
Super-Mod with a 240
Harris's Avatar
Send a message via AIM to Harris
It's supposed to be about four quarts. What motor do you have (I'm asking this so I can move it to the appropriate section)? I believe this is for an auto tranny, so it can't be four quarts. Please clarify what kind of transmission you have as well.
BTW, this has been discussed many times before. Please use the search function before asking questions.
"The greatest trick the devil ever pulled was convincing the world he didn't exist".
-The Usual Suspects
Harris is offline
post #4 of 10 Old Jun 16th, 2004, 11:57 PM Thread Starter
m_seats's Avatar
Thanks
I drained around 6 quarts so I put 6 back in. The dipstick says its full so i guess thats where I'l stop for now. If anyone knows different please tell me so I dont mess up my tranny. I forgot to mention that its a 1.6 and an automatic.
m_seats is offline
post #5 of 10 Old Jun 17th, 2004, 12:07 AM
Nissan Fanatic
Catman's Avatar
I drained about 6 quarts (with pan off), so it seems it may be similar. Haynes said capacity 2.6 quarts for drain and refill for automatic transmission. I find Haynes is off on some of their specs. I used Valvoline Maxlife Dexron 3. Seems to work just fine.
Catman is offline
post #6 of 10 Old Jun 17th, 2004, 09:40 AM
in^3,N20,RPM,PSI
James's Avatar
fill it till it says max then turn on the car and check it again, the tq converter can hold a lot of fluid.
05 Frontier SE CC 4x4 (6spd)
James is offline
post #7 of 10 Old Jun 17th, 2004, 10:43 AM Thread Starter
m_seats's Avatar
The liquid on the dipstick is a little over the full marking. I guess i will go let a little out. I want to make sure not to overfill it. Thanks James.
m_seats is offline
post #8 of 10 Old Jun 17th, 2004, 01:25 PM
Send a message via AIM to sicksilver99
on the complete sentra manual for the automatic 95-99 sentra ga16de it says it holds 7 and 3/8 quarts, and that ur suppose to use Nissan matic "D" transmission fluid. I am going to change mine this week.
sicksilver99 is offline
post #9 of 10 Old Jun 17th, 2004, 10:49 PM
i dont no where the hell they sell that nissan matic "d" fluid, maybe at a dealership. just make sure u get a/t fluid that says dextron III mercon. thats what the complete manual at autozone says if u dont use nissan matic "d".
mods- cat back exhaust, driving lights, sony xplod stereo, audiobahn 10" subs, sylvania silverstars/ future mods- custom cold air intake, timing advance, amp for subs, headers
post #10 of 10 Old Jun 17th, 2004, 11:43 PM
Post Freak
lshadoff's Avatar
Roughly 1/2 of the fluid is in the torque converter. There is no drain for the converter, so the amount of fluid you get out is different every time. The FSM says to measure the amount of fluid, and replace that amount.
When checking the fluid, run the shift selector through all the positions several times, and then check with the engine running and in Park.
The high stall converter I have in my car drains almost completely (takes about 30 minutes, though), so to fill I have to add about half the fluid, start the car, and shift it through the positions to fill the converter. Then I add the remaining fluid.
Lew
lshadoff is offline
  Nissan Forum > Sentra, Pulsar, NX, B14 200SX > B14 95-99 chassis
Gear in this thread
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Linear Mode Linear Mode
95 altima...changing transmission fluid sybert.net U13 1993-1997 Altima 4 Oct 10th, 2005 10:54 PM
Best Transmission fluid (MTX) to use? smithsil B13 91-94 chassis 7 Jun 15th, 2003 03:08 AM
97 gxe auto...where do i fill the transmission fluid? Shawn GA16DE 1.6L Engine 2 Mar 24th, 2003 10:12 AM
transmission fluid flush mtoa GA16DE 1.6L Engine 11 Jan 17th, 2003 11:58 PM
transmission fluid flush mtoa B14 95-99 chassis 6 Jan 16th, 2003 11:22 AM
You may post new threads
You may post replies
BB code is On
