Old Jun 9th, 2004, 09:58 AM   #1 (permalink)
im2kwik4u
im2kwik4u
im2kwik4u's Avatar
engine vibration (MOTOR MOUNT) maybe?
i hear a slight vibration sometimes when i let off the gas and the clutch. For example when im slowing down to a light and i just let it ride in second gear at about 2500-1500rpms, and i hear this vibration coming from the motor, and thats the only time i hear it. All i have is a front and rear strutbar, but i can not figure out where it is coming from, i also took out the strut bar to check and i still hear it. Is there anything that i should check for, PLEASE HELP!
thanks
1988 sentra E 4sp SOLD
1998 sentra GXE auto SOLD
1998 sentra SE SR20 Powa!!!
http://memimage.cardomain.net/member...00_90_full.jpg
im2kwik4u is offline   Reply With Quote
Old Jun 9th, 2004, 10:31 AM   #2 (permalink)
James
in^3,N20,RPM,PSI
James's Avatar
may be motor mount... does your strut bar contact your hood?
05 Frontier SE CC 4x4 (6spd)
Old Jun 9th, 2004, 10:52 AM   #3 (permalink)
97PocketRocket
I'd venture to guess it's the STB too. Check the hood at about the point where it's above the STB and see if some of the paint is rubbed off or there's a slight dent.
97PocketRocket is offline   Reply With Quote
Old Jun 9th, 2004, 10:59 AM   #4 (permalink)
schebs240
Send a message via AIM to schebs240
To check ur motor mounts simply drop it in first and if it goes into gear hard like a huge jump of the block then ur front mount is no good, for the rear mount as soon as u put it in reverse hit the gas light if it jumps hard then ur rear mount is no good.
Sorry i can't diagnose ur problem, thats a have to feel it to know it problem, vibrations can be from anything from a dist cap, to a bad connection.
schebs240 is offline   Reply With Quote
Old Jun 9th, 2004, 11:08 AM   #5 (permalink)
im2kwik4u
im2kwik4u
im2kwik4u's Avatar
can these be visually checked to see of they're damaged????
Old Jun 9th, 2004, 11:19 AM   #6 (permalink)
James
in^3,N20,RPM,PSI
James's Avatar
yeah just jack up the car and look. if it looks like the rubber is popping out its probably not serviceable.
Old Jun 9th, 2004, 12:19 PM   #7 (permalink)
im2kwik4u
im2kwik4u
im2kwik4u's Avatar
if they are damaged, do i just buy the rubber part of it, or do i need the whole mount. Can someone explain how to repair it
thanks for your responses
Old Jun 9th, 2004, 04:07 PM   #8 (permalink)
jer28
Nissan Fanatic
Do you have a press? If not buy the inserts and have a machine shop or a garage press them in for you. If you want to save a few dollars you could probally torch the old ones out.
jer28 is offline   Reply With Quote
Old Jun 9th, 2004, 05:06 PM   #9 (permalink)
RacinConcept
Send a message via AIM to RacinConcept
Well, when my mounts started to go, i got quoted a few hundred bucks for the set of four. I just bought the mtr mount set from sr20dev for $100. Had to take it to a shop for the install, and vibrates a lot more than stock, but worth it performance wise..and money wise. Just a suggestion. BTW, it was a bitch getting in contact with sr20dev. GL
-Andrew-
1996 200SX 1.6L
-Place Racing Intake w/JWT filter
-15" Konig Helium Wheels/Toyo FZ4
-Tein S. Tech Lowering Springs/AGX
-Tsubo muffler w/ 2" catback
-Nis-Knacks H4 Headlights
-SR20DEvelopment Solid Motor Mounts
-Exedy Organic Racing Clutch
-Zex 55-shot Wet Nitrous Kit
RacinConcept is offline   Reply With Quote
Old Jun 11th, 2004, 06:41 AM   #10 (permalink)
schebs240
Doesn't sound like u need them, why replace? and if u do? replace the hole thing its a very crucial part to half azz it.
92 1.6 engine vs 94 1.6 engine ? 92sentra92 GA16DE 1.6L Engine 2 Jul 14th, 2003 10:26 PM
trouble starting engine, engine dies when you give it gas LoOoD GA16DE 1.6L Engine 6 Jun 19th, 2003 05:44 PM
ga16de engine questions vashna GA16DE 1.6L Engine 1 Jun 17th, 2003 02:46 PM
Hurt engine, what do u think is wrong in it? pmftv E/CA-Series & GA16i Engines 5 May 23rd, 2003 12:35 AM
F1 engine plays a tune Mudge Off Topic 7 Dec 18th, 2002 02:33 AM
