Old Jun 1st, 2004, 04:22 PM   #1 (permalink)
SatanOfAZ
AC/Air Vents Problem
Hello,
I'm new to the forum, so go easy on me. I drive my girlfriend's '95 200SX. The only problem I've had with it is that I cannot switch which vents blow. No matter which ones i select, air only blows through the defrost vents that blow against the windshield (which does no good with the A/C for me during the Arizona heat). I took apart the center console. The 5-way selector is connected to a cable and sometimes the cable gets stuck and does not want to move, but even when it does, the vent selection does not change. The Haynes and Chiltons manuals and worthless to me. Anyone have any suggestions before I spend a day tearing apart the dash and everything else in it in hopes of finding something? Thanks in advance!
SatanOfAZ is offline   Reply With Quote
Old Jun 1st, 2004, 04:32 PM   #2 (permalink)
Ninety-Nine SE-L
Please Shift Here
Ninety-Nine SE-L's Avatar
Send a message via AIM to Ninety-Nine SE-L
the selector mechanism (where the cable leads to) is under the dash on the driver's side. You should see it to the right of the accelerator above the ECU.
There are 2 lieel arms that move up and down as you select the different vents, make sure they are moving and connected to the cable.
Ninety-Nine SE-L is offline   Reply With Quote
97 4cyl pickup engine cutout problem - help! Capncavedan Truck & SUV 81 Oct 21st, 2007 10:39 PM
NX2000 Cold Start Problem Seeking Help lucifer SR-Series Engines (DE/VE) 4 Mar 4th, 2005 08:18 AM
Shifting problem blazebridge U13 1993-1997 Altima 5 Jun 23rd, 2004 11:25 AM
Engine idle freaked out, went right back to normal sfhellwig GA16DE 1.6L Engine 27 Oct 24th, 2003 01:40 PM
97 Pickup EGR problem viper2 Truck & SUV 11 Aug 30th, 2003 06:27 AM
