Old Apr 30th, 2004, 10:59 AM   #1 (permalink)
noname
Reverse Problem?
I just recently purchased a 5-speed '98 200SX and it seems that the reverse is kinda tempermental on the car. Sometimes it takes forever to get it in reverse. Sometimes I let out on the clutch a little bit to try and get it to pop down into gear but it just grinds and I don't wanna mess anything up. I was wondering what's up with that and if theres a special way to make it do what you want... cause it ticks me off.
noname is offline   Reply With Quote
Old Apr 30th, 2004, 11:20 AM   #2 (permalink)
psuLemon
i pwn your mom
psuLemon's Avatar
Send a message via AIM to psuLemon
its prolly your bushings, i know a lot of our cars bushings get kinda hard after sitting awhile.. if you are completely stopped like you are suppose to be, it shouldn't grind.. there has been a discussion on this before, do a search and see if its still on the forums..
Originally Posted by hendrix
I can't wait until Hurrican Jamal sweeps up the east coast and steals the wheels and stero out of your car
psuLemon is offline   Reply With Quote
Old Apr 30th, 2004, 06:44 PM   #3 (permalink)
Nico Flax
Go Nerv!
Nico Flax's Avatar
Send a message via AIM to Nico Flax
Mine Kind has the same problem, I notice if you let it roll forward a little it pops in just fine, I have a theory about why it happens but my brain is kinda fried after exam week 1... so maybe later, still got exam week 2
Nico Flax is offline   Reply With Quote
Old May 1st, 2004, 12:07 AM   #4 (permalink)
jeffinbham
i smell that whore
jeffinbham's Avatar
i always put my 200 in first before reverse, otherwise it grinds, but i think i bent the shift linkage when i was dropping the tranny to replace the clutch. it's not a solution, but it still aleviates the problem, for the most part. don't know if that helps.
96 200sx se-r
tein basics with pillow ball mounts, enkei 18s, b&m short shifter, 2.25" exaust with magnaflow, act street disc and HD pressure plate, aem cai, prothane motor mounts, topspeed header
jeffinbham is offline   Reply With Quote
Old May 1st, 2004, 12:14 AM   #5 (permalink)
200sxOuTKasT
200sxOuTKasT's Avatar
It just happens, a lot of us complain about it, but nothing can be done about it. Our car's transmission is just stupid like that. It happens in my friend's car, it happens in mine, both are "newer" and treated quite well so we just figured it was a flaw built into our cars.
91 240sx
98 200sx SE (Long gone...)
My 200sx Timeslips as of 04/11/04
Injen Short Ram Intake, custom 2" mandrel bent piping, Magnaflow muffler
200sxOuTKasT is offline   Reply With Quote
Old May 1st, 2004, 09:40 AM   #6 (permalink)
Something Funny
Something Funny's Avatar
Send a message via MSN to Something Funny Send a message via Yahoo to Something Funny
what i do when my car does this is put the car back in neutral and let out on the cluctch. then just put it reverse
Something Funny is offline   Reply With Quote
Old May 1st, 2004, 09:50 AM   #7 (permalink)
lshadoff
Post Freak
lshadoff's Avatar
This could also be due to the clutch not completely disengaging. Since the forward gears are synchromesh, they can engage with the clutch slightly dragging. But, reverse is not synchromesh and will grind if the clutch is not completely disengaged.
Also, if the gears are spinning when you try to engage reverse, it will grind until they stop. If you put it into 1-st or 2-nd the gears stop, allowing reverse to be engaged more easily if you do it right away.
Lew
lshadoff is offline   Reply With Quote
Old May 1st, 2004, 10:47 AM   #8 (permalink)
Jaralaccs
Jaralaccs's Avatar
Send a message via AIM to Jaralaccs
I've gotten so use to this problem that instead of going straight to R, my mind just puts it in 4th ands swings it around into R unconsciously
shut up
Jaralaccs is offline   Reply With Quote
Old May 1st, 2004, 07:17 PM   #9 (permalink)
200sxOuTKasT
Yeah, we each have our own "thing" we do for this problem now I see I myself always press on the clutch twice before going into reverse, and I notice that I rarely ever get this problem anymore.
91 240sx
Old May 2nd, 2004, 12:44 AM   #10 (permalink)
psuLemon
i pwn your mom
psuLemon's Avatar
all i can say... if you can't find it, GRIND IT
Old May 3rd, 2004, 02:12 AM   #11 (permalink)
ReVerm
Boxed Fox
ReVerm's Avatar
Actually, that's what a gear without synchros feels like. The only reason a lot of newer cars don't have that problem now is that so many people kept grinding reverse that manufacturers started using single (sometimes double) synchro reverse gears.
Captain Slow.
Old May 5th, 2004, 02:37 PM   #12 (permalink)
sfhellwig
Nissan Fanatic
Can also be influenced by how old the fluid is. My 98' does the not going into reverse much worse now than it ever did in its first years. I also have to double clutch 2nd and 3rd alot. I have seen many people say a fluid change relieved the need for double clutching so I am assuming when I finally change mine to Redline it will help the reverse shift issue some. Just a thought.
too poor to enjoy.....
sfhellwig is offline   Reply With Quote
Old May 5th, 2004, 05:05 PM   #13 (permalink)
psuLemon
i pwn your mom
psuLemon's Avatar
newer fluid can help but it might be you have a bad clutch...
Old May 5th, 2004, 07:02 PM   #14 (permalink)
viprdude
Nissan SE-R Owner
viprdude's Avatar
wait till ur stopped completly, clutch in, clutch out, try again. voila.
http://www.cardomain.com/id/viprdude
Updated 7/15 - Now with VRS 2.5" hi flo cat, cat-back with 20" resonator and magnaflow muffler and a weapon r header! Video on site!
viprdude is offline   Reply With Quote
Old May 6th, 2004, 01:07 AM   #15 (permalink)
psuLemon
i pwn your mom
psuLemon's Avatar
or just give it a little tap tap taparoo... that helps...
Shifting problem blazebridge U13 1993-1997 Altima 5 Jun 23rd, 2004 11:25 AM
Reverse light..The saga continues Bugalou B11/B12/KN13 82-90 chassis 10 Apr 29th, 2004 04:50 PM
Reverse light problem on 88 pulsar Bugalou B11/B12/KN13 82-90 chassis 3 Apr 25th, 2004 07:11 AM
Engine idle freaked out, went right back to normal sfhellwig GA16DE 1.6L Engine 27 Oct 24th, 2003 01:40 PM
tranny problem 97sentragxe Truck & SUV 0 Feb 19th, 2003 09:11 AM
