Old Feb 17th, 2004, 03:20 PM   #1 (permalink)
Ninety-Nine SE-L
Please Shift Here
Ninety-Nine SE-L's Avatar
Send a message via AIM to Ninety-Nine SE-L
Unhappy AW CRAP!!! :( Front wheel bearing, HELP
Jus brought my car into Nissan. I just put sportline springs in the front today and I decided to get it aligned as well. Right away, I felt my alignment was terrible, I was gettin very excessive play on the wheel.
While the car was in, I wanted them to look at a horrible squeek, popping, grinding noise, I've been getting in the driver's wheel. At first I thought it was the axle, then the tranny, then the bearings, then the motor mounts, then the brakes, I kept having it looked at and it kept coming out with no problems. They told me there was something rubbing against the rotor.
This time I had a different place look (the place that's currently doing the alignment). I jus got a call that it's the bearings. He described it as one of the bearings is scraping in the hub. He told me it's a $400 job (which I can't afford now)
I want to do this mself, but I don't know what needs to actually be replaced. Can someone show me a breakdown of the assembly, tell me what needs to be replaced, what to do, and so on? I want to save the labor cost on this bitch. What parts will I need?
Does anyone know if this could be related to my accident?
Ninety-Nine SE-L is offline   Reply With Quote
Old Feb 17th, 2004, 03:31 PM   #2 (permalink)
LIUSPEED
Vendor
DNE's VZR Conversion
LIUSPEED's Avatar
Send a message via AIM to LIUSPEED Send a message via MSN to LIUSPEED Send a message via Yahoo to LIUSPEED Send a message via Skype™ to LIUSPEED
it sounds like it is
LIUSPEED is offline   Reply With Quote
Old Feb 17th, 2004, 04:19 PM   #3 (permalink)
sethwas
what?
sethwas's Avatar
Yeah,
I just had my front bearings replaced. All that Canada Snow and NE Snow caused them to dry out and rust. It was just under $400.
Seth
my signature is at the bottom of this thread. its because its too long. Lots of important links there.
http://www.nissanforums.com/showthread.php?t=46259
sethwas is offline   Reply With Quote
Old Feb 17th, 2004, 05:03 PM   #4 (permalink)
Kalel
Lord of Cut & Paste
Kalel's Avatar
I just had my front bearings replaced about 2 weeks ago and it cost me all together about $220
2 front bearings from autozone=$40*2=$80
Getting them pressed = $30 (for both)
labor to install $95
…….………………………_______
.………….……...==_//__||__.\_____
………………..…[_( O )__|___( O )__\
My Life Story.………..……``…...…….…``......
Kalel is offline   Reply With Quote
Old Feb 17th, 2004, 05:17 PM   #5 (permalink)
Ninety-Nine SE-L
Please Shift Here
I may go that route. tell me, what is pressing them? who does that work? is that all I need or do I need a new hub? Where did you go to have them installed?
Old Feb 18th, 2004, 08:13 AM   #6 (permalink)
Raul
If it were mine, I would replace the whole spindle assembly with one from the wrecking yard. Prices average bout 100 bucks -- some way below that, some way above it -- go figure.
Depends on your mechanical ability, tools, work space, and personal inclination.
But that's what I'd do.
Raul
91 Sentra E, 1.6, 3-sp A/T
96 Sentra GXE, 1.6, 4-sp A/T
81 F-100; 89 Jeep; 93 Grand Caravan
Raul is offline   Reply With Quote
Old Feb 18th, 2004, 08:46 AM   #7 (permalink)
Kalel
Lord of Cut & Paste
Kalel's Avatar
My mechanic a friend of the family took me to some place to get them pressed. He took of my hub asembly both of them and we drove down to 135st and alibaba ave. (place down here in miami) took apart the HUB and replaced the wheel bearings. i thought i needed a new HUB also but turns out that i didn't. I'm think you could take it to pepboys or something to get them pressed.
…….………………………_______
Old Feb 18th, 2004, 09:30 AM   #8 (permalink)
Ninety-Nine SE-L
Please Shift Here
Ok, so if I'm understanding this, I take the hub off (how hard is this?), I take it into auto zone, buy new bearings and have them pack the new ones into the hub, then I reinstall the hub?
what's the $95 labor for?
Old Feb 18th, 2004, 07:53 PM   #9 (permalink)
Bryan200sx
Nitrous Junkie
Bryan200sx's Avatar
Send a message via AIM to Bryan200sx
same problem
Some one should do a write up there seems to be alot of people that have the same problem i have the same problem but on the passenger side wheel it sounds like a click click click when im amost stoped and braking or accelerating i would like to also do it my self and avoid the cost of the having a mechanic do it for me
Nitrous is like a hot girl with STD's you wana hit it but are afraid of the consequences.
http://www.cardomain.com/member_pages/view_page.pl?page_id=626608&cat=25&val=1
Bryan200sx is offline   Reply With Quote
Old Feb 19th, 2004, 06:55 AM   #10 (permalink)
Kalel
Lord of Cut & Paste
Kalel's Avatar
Yeah basically taking ofthe hub is a b*tch and a half you got to take of the brake disconnected it from the cv-joint and everything else thats connected with it. took about 20 mins to get each one of them off with the right tools.
…….………………………_______
Old Feb 19th, 2004, 02:15 PM   #11 (permalink)
ReVerm
Boxed Fox
ReVerm's Avatar
Bearings need to be pressed into the hub. It's not something you can do without a one ton or so press.
You can take them to a machine shop to get them pressed. Donno what they'll charge though. I've never done that.
Captain Slow.
Old Feb 19th, 2004, 02:36 PM   #12 (permalink)
Ninety-Nine SE-L
Please Shift Here
I think I need an entire new hub as it is, I think the bearing has messed up the hub.
lemme see here:
1. get the old hub out (bearings are packed into the hub)
2. get a new hub (does a new hub come with new bearings?)
3. install the new hub
is this what I'm looking at?
Old Feb 19th, 2004, 03:58 PM   #13 (permalink)
ReVerm
Boxed Fox
ReVerm's Avatar
lemme see here:
Well, here's the problem. Once you remove the hub from the knuckle, you've broken the seal and you'll need to have the bearing repacked. I'd just try to find a low mileage spindle like Raul suggested.
Captain Slow.
Old Feb 20th, 2004, 02:14 AM   #14 (permalink)
san_fran_b14
Back 2 SF
san_fran_b14's Avatar
Send a message via Yahoo to san_fran_b14
I think I may have the same problem with my sentra. When the car's in a complete stop, it's really quiet but when i start to accelerate, it makes a grinding sound and it gets more noticeable when i turn to the left and when i go faster. I want to go to the mechanic to get it fixed but I'm kinda worried on how much it's gonna cost me to have it repaired....
san_fran_b14 is offline   Reply With Quote
Hilarious story LethalAudio Off Topic 13 Nov 13th, 2003 10:41 PM
Gtp sentra_hilo Cosmetic Mods 7 Jul 13th, 2003 11:09 PM
front wheel bearing the don 1600 B13 91-94 chassis 10 May 22nd, 2003 08:15 PM
Need wheel bearing.. Mike92se B13 91-94 chassis 2 Aug 29th, 2002 01:19 AM
