Old Jan 26th, 2004, 04:37 PM   #1 (permalink)
Neva2wicked
I want my B14!!!!
Neva2wicked's Avatar
Send a message via AIM to Neva2wicked Send a message via Yahoo to Neva2wicked
Angry A little help (Yes I've searched)
One of the bulbs on my car blew and I can't get the assembly out so I can replace it. Can anyone point me in the right direction? Kinda sucks considering its easy to take off the rear lights, yet am completely unable to get off the front ones.
Thanks a bunch
P.S. Yes I've searched using "b14 headlight removal", "bulb replacement", "light assembly removal", "bulb installation", and a dozen other names.
Neva2wicked is offline   Reply With Quote
Old Jan 26th, 2004, 04:59 PM   #2 (permalink)
Wufaded
THINK BLUE
Wufaded's Avatar
Send a message via MSN to Wufaded
so you just wanna swap out the bulbs from your headlights, right??
Club MoFo Votary - My 200SX
Wufaded is offline   Reply With Quote
Old Jan 26th, 2004, 05:04 PM   #3 (permalink)
zeno
Paging Mr. Herman
zeno's Avatar
Thanks a bunch
huh? Are you asking about the front or rear lights? To get the headlights out, pop the hood and look for a little wire latch behind the headlamp assembly. Undo that and that's it.
Garage Sale - buy my junk!!
My Car!
Dreaming of turbo..... :fluffy:
zeno is offline   Reply With Quote
Old Jan 26th, 2004, 05:23 PM   #4 (permalink)
NotAnotherHonda
Have I Hit 12's Yet?
NotAnotherHonda's Avatar
yea...the ones in the front are simply held on with a snap kinda thing
95 200sx se. sr20de, gt28r, bb manifold, forge fmic, greddy bov and bc, tial 38mm, walbro 255, apexi tt, 3" exhaust with magnaflow, 3" downpipe, jgy clutch flywheel and fuel rail, msd 50#'s, cobra maf, jwt ecu and s4's, nismo fpr, autometer, nissport adaptors, fal pushers, ur pulley, m/t 22x8x15 et drags.
NotAnotherHonda is offline   Reply With Quote
Old Jan 26th, 2004, 05:34 PM   #5 (permalink)
Captain Obvious
Oh Ya
Send a message via Yahoo to Captain Obvious
and the rear is a twisty thing they might be a little stuck but just jwist them and theyll come out the front ones looks lika a metal hanger of sorts just pull hard but dont get your fingers snaped like I did it hurts like a biatch
Captain Obvious is offline   Reply With Quote
Old Jan 26th, 2004, 05:40 PM   #6 (permalink)
clsindustries
Send a message via ICQ to clsindustries Send a message via MSN to clsindustries
As straightforward as the job SEEMS like it should be. There's an inordinant amount of crap around the headlight that you'll have to work around. I can only imagine that if you have thick fingers this job is gonna be a major PITA.
Just look on the back side of the headlight assembly. There'll be a plug that you'll need to pull and I believe there's a wire type clamp you'll need to pull off BEFORE you yank the plug out of the headlight.
Patience and a good well placed yank should do the trick.
Carlos
99 Platinum Gold Sentra SE-L
'Breathin' easy in and out! Thank you Magnaflow!'
clsindustries is offline   Reply With Quote
Old Jan 27th, 2004, 10:34 AM   #7 (permalink)
Exalta
Avtomat Kalashnikov
Exalta's Avatar
Send a message via ICQ to Exalta Send a message via AIM to Exalta
If you still have the manual, there are detailed instructions regarding the aforementioned topic there.
If not: Just follow what they said.
-Pull off the bulb plug by pressing on its side and pull
-twist the plastic cap counterclockwise to remove it
-pull off the rubber seal using its tab
-take off the retaining clip
Be sure to put those back properly as to avoid dirt/soot from getting inside your headlights.
2000 Nissan Exalta Sentra STA (B14) /2003 Nissan X-Trail /
NissanBayan PI
(Click on the links above)
Exalta is offline   Reply With Quote
SE-R to Spec V Conversion (already searched) TofuShop General Discussion 7 Jan 20th, 2004 01:57 AM
iacv (already searched) jer28 GA16DE 1.6L Engine 7 Oct 27th, 2003 09:59 AM
I've searched themudboy GA16DE 1.6L Engine 1 May 13th, 2003 11:47 AM
im confused about intake stuff (yes i've searched) G2-0-0SX B14 95-99 chassis 2 Apr 29th, 2003 10:05 PM
B13 A/C REMOVAL (yes I searched!!) 91SR20DE B13 91-94 chassis 2 Mar 21st, 2003 05:29 PM
