Originally Posted by myoung
It's a Temp sensor...
There should have been a small plastic piece (tube) that went downward into the fender off the stock airbox... you can leave that there with the temp sensor plugged in.....it won't interfer with anything. You'll have to reset the code on the ECU... or it will clear on it's own after a short while if the temp sensor is reading properly.
tried to make easy to understand...
good luck
What he said
You must've unplugged the sensor when you took the tubing out. Find that sensor, plug it back into the wire plug, and zip tie it to the side where it's out of the way. It's not too important of a sensor, jus make sure it's in an area near the intake filter.
