PO 505: Idle Control System Malfunction. - Nissan Forum
post #1 of 5 Old Dec 3rd, 2003, 04:51 PM Thread Starter
shibapj's Avatar
Question PO 505: Idle Control System Malfunction.
Folks,
My Sentra GXE (96 make) threw up a 'Check Engine' dashboard warning symbol suddenly. The diagnostic says 'PO 505: Idle Control System Malfunction'. One kind soul told me it is the 'Idle Air Control Valve' which needs to be repaired/ replaced. Any idea/ suggestions? Would appreciate your help.
Thanks.
shibapj is offline
post #2 of 5 Old Dec 3rd, 2003, 05:17 PM
the exact same thing happened to me. you will probably have to replace the valve. it shouldnt cost more than $200 dollars. im sure the valve has gone bad, as this has happened with many people with 1995-1998 sentras, particularly the ones built in mexico. most nissan dealers should have the part.
dfalcon02 is offline
post #3 of 5 Old Dec 3rd, 2003, 05:33 PM
Nissan Fanatic
The same problem has come up on alot of cars but I haven't seen alot of people replace them. Try cleaning with TB cleaaner first, then replace. Awfully expensive part to find out that wasn't it.
too poor to enjoy.....
sfhellwig is offline
post #4 of 5 Old Dec 4th, 2003, 02:13 PM Thread Starter
shibapj's Avatar
Thanks for your replies. It was quite an eye-opener. What is the TB Cleaner and how do I clean the valve with this? I fully agree the valve cld be too expensive.. Wld the engine or any system get damaged for a faulty valve?
shibapj is offline
post #5 of 5 Old Dec 4th, 2003, 02:37 PM
Nissan Fanatic
The engine wouldn't be damaged by this particular valve, it would just cause the car to run poorly. It usually shows up as a lumpy idle. Odd that it throws a code and the car isn't running funny. TB stands for Throttle Body and you can get the cleaner at most auto stores. I just removed the valve, sprayed it with the cleaner, and wiped it down with Q-tips very gently. This turned out to not be my problem so I don't know what a malfunctioning valve would act like.
  Nissan Forum > Sentra, Pulsar, NX, B14 200SX > B14 95-99 chassis
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Linear Mode Linear Mode
Problem with traction control system. Thig L31 2002 - 2006 14 Oct 23rd, 2014 08:25 PM
EVAP canister vent control valve closed large168 SR-Series Engines (DE/VE) 45 Mar 24th, 2013 01:08 PM
cruise control weirdness b15 SE auto ZoliElo B15 2000-2006 0 Mar 9th, 2003 04:15 AM
emission control system 96GXE B14 95-99 chassis 0 Jun 16th, 2002 01:41 PM
You may post new threads
You may post replies
BB code is On
