i was always told that 91'-94' sr20de motors didnt fit in 95-99 b14s because the motor mounts are different i think (correct me if this info is wrong)... i was on ebay and i was looking at a usdm sr20de motor from a 91' nx2000..... and it says that u could drop it in a 95' g20 or 200sx with a few mods.....how would u mod it to make it fit in a b14?????
We all live in a yellow submarine, a yellow submarine, a yellow submarine....
Ok enough singing Beatles stuff, now do yourself a huge favor and search. Whoever told you about the SR20 not fitting a B14, especially those that come from B13s, needs to hit themselves in the head for talking shit. I hate it when people say something they don't know squat about.
"The greatest trick the devil ever pulled was convincing the world he didn't exist".
It will bolt in. If your doing a 1.6 to 2.0 swap you will need the mounts, tranny, and a whole heap of other parts.
so does this mean i could use any se-r tranny?....and what MAIN parts would i need?.....would this be tooo much trouble to go through???....this is confusing because of the 95-99 and 91-94 thing
95' 200sx 1.6....hotshot headz, BOMZ intake (ghetto), 12 degrees advance, act street clutch, b&m short shifter...coming soon: se-r side skirts, stillen front lip, unorthodox pulley
what ever happened to pogs??
You need to research this more. There ar e alot of posts about the 1.6 to 2.0 swap. The year difference is not an issue because you are changing motors all together. Any SE-R tranny wirll work FWIW. Just try and get a 91-97 as 98's and 99's do not have LSD's. CHeck out the SR20 forum here and sr20forum.com for more info.
thanx
hi..
..did you have any luck about the swap?!! ..I jus' found a '92 SER going for $100 from a local wreck yard. Its the whole car..& the engine looks good too.
