Old Nov 25th, 2003, 10:25 PM   #1 (permalink)
G2-0-0SX
the moon rules #1
G2-0-0SX's Avatar
Send a message via AIM to G2-0-0SX
Odd rear wheel tread loss
Ok so I'm at my new job now, and I drive about a 65 mile drive round trip and I drive it 6 days a week. Lately I've noticed that the tread on my off-brand tires is wearing out really badly on the back left side mostly, its also very bad on the back right, but the left is the worse...all the tread is bald on the outside of the wheel...almost as if it has REALLY bad posotive camber, but I cant really tell how the camber is on the rear...looks fine to my naked eye. Anyways I went ahead and got them rotated, and with my check i'm getting in 2 weeks I'm going to buy some good tires (the ones I have now came with my rotas) Can anyone reccomend some really good long lasting tires? And does anyone know what the problem might be?
thanx.
"SHIFT INTO AWESOME!! AND THEN SOME!" My lil black 200sx
[Rota's, Tein/AGX, catback, WAI, strut bars, custom gauges, xplod, short shifter, razo knob, smoked tails, stealth headlights/corners, grille, splitters, M3 mirrors, catch can, 20% tint, etc...]
G2-0-0SX is offline   Reply With Quote
Old Nov 30th, 2003, 12:52 PM   #2 (permalink)
JT200SX-N-FX
Hang out wit yo Wang out!
JT200SX-N-FX's Avatar
Send a message via AIM to JT200SX-N-FX
How long have you had your rear struts? you might need new ones, if they are good, it's most likely you need an alignment, the B14 rear doesn't really have a bad camber problem because of our beam setup. Next time you drive roll your windows up, and turn down the music, listen for a whopping sound in the rear. I had this problem when I first got my 200.
Pics of my Ride!
http://mysite.verizon.net/vze1zp2e/units/jtstyle/
JT200SX-N-FX is offline   Reply With Quote
Old Nov 30th, 2003, 10:16 PM   #3 (permalink)
azkicker0027
Cone Dodger
azkicker0027's Avatar
Send a message via AIM to azkicker0027
any tire wear issues, always check the alignment, tire pressures, and in some worse cases, dragging brakes.
Naturally aspirated autocross car.............naturally.
http://members.cardomain.com/azkicker0027 And defending STF in the process.
http://www.200sxonline.com/community/
azkicker0027 is offline   Reply With Quote
Old Nov 30th, 2003, 10:36 PM   #4 (permalink)
G2-0-0SX
the moon rules #1
G2-0-0SX's Avatar
any way to tell dragging brakes?? My rear brakes allways stick and friday im getting new rears when I get my new tires, im also getting my friend to align the car, so hopefully that will fix everything. Is there any way to tell for sure if its dragging brakes?
thanx everyone.
Old Dec 1st, 2003, 08:38 AM   #5 (permalink)
azkicker0027
Cone Dodger
it's kinda rare for dragging brakes, like i said, worse case, but if it does, the brake shoes and hardware don't disengage fast enough, and the wear on the shoes are really fast compared to the other side, but like i said, that's worse case.
Old Dec 1st, 2003, 05:56 PM   #6 (permalink)
sersr20dk
Send a message via AIM to sersr20dk
i'm going to say check the rear struts also, also check the wear again, look to see if it is a little choppy, uneven tread wear will indicate a strut problem. don't put new tires on until you figure out why the old ones wore improperly.
DnS Performance
sersr20dk is offline   Reply With Quote
Old Dec 1st, 2003, 06:05 PM   #7 (permalink)
200SushiX
Yokohama AVS ES100's; I've had them for about a
month and love them. They're not the longest lasting,
but are nice and quiet and have good grip.
Or Bridgestone Potenza RE750's. They have a
360 treadwear rating, (Yokohama's 280); however,
I read a Tirerack comparison test that said wear was
similar between the two, and their individual ratings
may be missleading?
Always get an alignment with new tires. But aren't the
rear wheels unadjustable?
200SushiX is offline   Reply With Quote
Old Dec 2nd, 2003, 11:40 AM   #8 (permalink)
sersr20dk
yes the rear is unadjustable, thats why i say struts
DnS Performance
Old Dec 19th, 2003, 03:17 PM   #9 (permalink)
G2-0-0SX
the moon rules #1
G2-0-0SX's Avatar
found the problem about 2 weeks ago, i forgot about this post and just want to update incase someone has this problem in the future and does a search or something...anyways yea, my rear axle was bent to hell and back, but i got a whole new assembly with brakes and lines and e brake cables and everything perfectly straight from a 98 for $150 from a junkyard and my friends and I changed it all in about 2 hours. It actually rides a whole hell of alot better now, especially on the freeway...it doesnt wobble like crazy and seem to veer back and forth, and i've had my new tires (Dunlop Sp Sport FM901's 195/55/15) for about 2 weeks now and there are no signs of odd tread loss, so its all good now.
Old Dec 19th, 2003, 07:29 PM   #10 (permalink)
Arsenal200SX
Arsenal200SX's Avatar
Send a message via AIM to Arsenal200SX Send a message via Yahoo to Arsenal200SX
good to hear man,i cant imagine what a bent rear beam is like..must have sucked
96 200SX 1.6L
Injen WAI,Eibach Prokits w/ KYB AGX,rear Motivational mounts. 2 inch crushbent exhuast.
95 240SX (being ressurected)
Arsenal200SX is offline   Reply With Quote
Old Dec 20th, 2003, 10:41 PM   #11 (permalink)
G2-0-0SX
the moon rules #1
G2-0-0SX's Avatar
Yes, it did suck some major ass, not just ride quality either, but every time I looked at my car since the front has slight negative camber and the back *had* posotive rear camber...the different camber contrasted so much and it just looked horrible at certain angles.
D21 rear disc brake conversion scoobysmak Truck & SUV 13 Jul 5th, 2006 05:58 PM
New suspension Group bys ILP Performance Group Buys 4 Aug 31st, 2005 02:09 PM
SEMA show Spec V's and other Nissan GOODIES cjsmith11878 General Discussion 13 Jan 26th, 2005 09:51 AM
B12 Sentra rear susp sinking problem nyit240 B11/B12/KN13 82-90 chassis 17 Sep 2nd, 2004 06:46 AM
ugly rear wheel center piece pearsont74 Cosmetic Mods 4 Sep 6th, 2003 03:12 AM
