Old Nov 14th, 2003, 08:31 PM   #1 (permalink)
Nissusan
ECU Reset help
I followed the directions on sentra.net, but have a couple of questions..
1) When the article refers to the "flashing light" is it the check engine light that should flash?
2) I want to reset the ECU,... do i put the key in and turn it to the ON position, then turn the screw on the ECU clockwise. Then ofcourse turn it counter clockwise after 2 secs.... OR..... should i at any time remove and reinsert the key, will that make a difference.
3) The tape that was on the ECU, has a diagram that seems to indicate that i should turn and stop. Diagnose the problem. Then when finish, just turn it back to it's normal mode, kinda like ON, and OFF/Diag.
Nissusan is offline   Reply With Quote
Old Nov 14th, 2003, 08:34 PM   #2 (permalink)
azkicker0027
Cone Dodger
azkicker0027's Avatar
Send a message via AIM to azkicker0027
the CEL light will flash your codes, and when you pull up the codes and return the position as stated in the sticker, it will automatically reset the ecu and clear the codes without the need to cycle the ignition.
Naturally aspirated autocross car.............naturally.
http://members.cardomain.com/azkicker0027 And defending STF in the process.
http://www.200sxonline.com/community/
azkicker0027 is offline   Reply With Quote
Old Nov 15th, 2003, 06:25 AM   #3 (permalink)
Nissusan
Thanks.. nissan should of made the ecu facing the opposite direction, but i guess they don't want u messing with it.
