Old Nov 14th, 2003, 01:55 PM   #1 (permalink)
AnthMC
Send a message via AIM to AnthMC Send a message via Yahoo to AnthMC
info on a 99 Sentra Header replacement
Hey everyone, well I have been looking around and trying to do my homework, but is it hard to replace a header on the 1.6 GA16DE engines?? I'm looking to go with a hotshot header for some extra power..... What should I look for when I got to replace it? Just replace the gasket and direct bolt on? And would it hurt it if only replaced the header and not the whole pipes back to the exhaust, which I plan to do, just can't all at once....... Just looking to see if anyone has some advice or info about it. Also I plan on picking up a repair manuel to help me with the replacement.... looks easy, but are looks being deceiving? Thanks everyone!
AnthMC is offline   Reply With Quote
Old Nov 14th, 2003, 04:19 PM   #2 (permalink)
1CLNB14
I command you to SEARCH
1CLNB14's Avatar
Send a message via Yahoo to 1CLNB14
With the 99 1.6 (if it's anything like mine) you will have to replace damn near everything...(which is good to do in this situation anyway).
Sean M.
"Can you feel it building? Devastation is on the way!"
1CLNB14 is offline   Reply With Quote
Old Nov 14th, 2003, 04:30 PM   #3 (permalink)
sentra_hilo
Nissan Fanatic
replace the gaskets and you have to relocate your 2nd 02 sensor to behind your cat. other than that its a bolt on
my b14:http://members.cardomain.com/sentra_hilo
sentra_hilo is offline   Reply With Quote
Old Nov 14th, 2003, 06:36 PM   #4 (permalink)
wes
Wise Cracker
wes's Avatar
Send a message via AIM to wes
It's a 99, he'll have to get a cat first.
You will need the header, a cat to place under the car (OEM SE-R cat works perfect) and you will have to modify the exhaust to meet up to the cat. It's easiest to do everything at once so you don;t have to shell out $$ to modify the crappy stock exhaust that you will eventually replace anyway. Save your pennies and do it all at once, you'll save $$$ in the long run.
www.NissanPerformanceMag.com
JWT
www.notnser.com
