What causes a car to be "flooded with fuel"? - Nissan Forum
post #1 of 16 Old Nov 11th, 2003, 09:32 PM Thread Starter
200sxOuTKasT's Avatar
Question What causes a car to be "flooded with fuel"?
My earlier post in the GA16DE forums about my car not starting was solved by easily stepping on the gas and and clutch and starting the car. I had asked one of my friends what could be my problem and he said that too much fuel was pumped and that my engine was flooded with too much fuel and to hold down the gas while starting the car to clear it. Now my question is, what exactly causes a car to be flooded with fuel? He says his manual cars have had it happen a couple times, but his automatics never have the problem. Several of my friends agreed to this and have had this happen; this was my first time having it happen. I have all my sensors on correctly and I don't have the CEL/SES light on, so what could've caused this? Is there something wrong with my fuel injection system? Thank you for your time.
91 240sx
(Long gone...)
Injen Short Ram Intake, custom 2" mandrel bent piping, Magnaflow muffler
200sxOuTKasT is offline
post #2 of 16 Old Nov 12th, 2003, 12:21 AM
Send a message via AIM to sersr20dk
your engine isn't flooded, you probably just need a new fuel filter, by pumping the gas pedal you are increasing pulse rate of your injectors because it see's the tps moving, eventually after doing that, the car has enough fuel and finally starts. try a fuel filter and let me know, do your friends know its hard to flood a fuel injected car?
DnS Performance
sersr20dk is offline
post #3 of 16 Old Nov 12th, 2003, 12:22 AM
Cone Dodger
azkicker0027's Avatar
Send a message via AIM to azkicker0027
flooded cylinder is mostly the misconception of flooring the accelerator while cranking engine, this is also most common on carb'ed engines, wherein fuel is dumped in the manifold. but on fi cars, the tps sends a wot signal, thus requiring the injectors to allow fuel to go in the manifold, but without spark, the fuel vapors just stay and accumulate, the spark plug gets wet, and the cylinder walls washed down reducing compression, and a no start/long crank condition.
Naturally aspirated autocross car.............naturally.
Retired STF champ car.
azkicker0027 is offline
post #4 of 16 Old Nov 12th, 2003, 01:16 AM
Boxed Fox
ReVerm's Avatar
For future reference, if you actually do flood your engine, the best way to clear it is to just wait a while before you start it.
Captain Slow.
ReVerm is offline
post #5 of 16 Old Nov 12th, 2003, 11:24 AM
SE Limited
sentravis's Avatar
Send a message via AIM to sentravis Send a message via Yahoo to sentravis
umm.. i thought (and correct me if im wrong) that you could only flood an engine if you had a carb. engine. and not if you had EFI motors??? and i thought that would only happen when the car is completely off and you would push on the pedal and hold down on it.. (if it was a carb.)?? Travis
_1999 Sentra SE-L_B14X platform_
Originally Posted by little240boy
morons like this start threads all the time. They probably want a 240sx because its what is hot right now instead of a honda civic and wants to drift in a shopping parking lot...dumb and unsafe.guys like this can't handle the power of a vehicle and want the numbers for bragging rights,only to find themselves wrapped around a tree.
sentravis is offline
post #6 of 16 Old Nov 12th, 2003, 01:06 PM
Boxed Fox
ReVerm's Avatar
It's still possible with an EFI engine. Normally it happens when you have problems starting up (the engine will crank but won't start), and you just keep it cranking for too long (all of the fuel gets dumped in, but not enough of it is combusted). There are other ways to do it, but that's usually how it happens.
Captain Slow.
ReVerm is offline
post #7 of 16 Old Nov 12th, 2003, 01:17 PM
in^3,N20,RPM,PSI
James's Avatar
a leak in the o rings will flood an engine as well...
05 Frontier SE CC 4x4 (6spd)
James is offline
post #8 of 16 Old Nov 12th, 2003, 10:54 PM
Cone Dodger
field fix, take out and clean the plugs with throttle body cleaner, squirt small amount of oil in cylinders, wait a while, then start it up, and don't mind the blue smoke.
post #9 of 16 Old Nov 12th, 2003, 11:52 PM
Boxed Fox
ReVerm's Avatar
One thing I did forget to mention before:
Have your battery checked as well. I actually can't find your older post (I'm not looking hard enough), so I don't know if you have, but if you haven't, I suggest you do it.
Captain Slow.
ReVerm is offline
post #10 of 16 Old Nov 12th, 2003, 11:53 PM Thread Starter
Thank you everyone for your replies, it has helped and taught me a lot.
91 240sx
(Long gone...)
post #11 of 16 Old Nov 13th, 2003, 06:02 AM Thread Starter
Actually it just suddenly occured to me, although I know what caused the problem now, should I have any concerns about my engine now that the problem is gone? Should I replace some stuff? Fuel filter? Spark plug and wires? Distributor? Full engine tune up?
91 240sx
(Long gone...)
post #12 of 16 Old Nov 13th, 2003, 01:05 PM
Boxed Fox
ReVerm's Avatar
What was the problem?
Captain Slow.
ReVerm is offline
post #13 of 16 Old Nov 14th, 2003, 01:55 AM Thread Starter
The problem was that my engine was flooded and the simple fix was just to wait a while and start the engine by holding onto the gas and clutch while turning the key which I heard was to make the engine start out lean or something like that. I'm just curious now that this has occured, should I be worried about other components in my engine whether they could've been damaged by this ordeal or they caused it? If so what components would they be?
91 240sx
(Long gone...)
post #14 of 16 Old Nov 14th, 2003, 02:57 PM
Boxed Fox
ReVerm's Avatar
Oh. I thought you meant that you had discovered what caused the problem.
Captain Slow.
ReVerm is offline
post #15 of 16 Old Nov 15th, 2003, 10:27 AM
you must need a tune up, plugs, wires, cap, rotor, and fuel filter at least. you need to determine why your engine was flooded. are you sure your engine was flooded?? who diagnosed this? when you started the car, was there initially black smoke, or a strong smell of unburnt fuel? i wouldn't be surprised if this comes back, if it was caused by your engine flooding for sure, check the tps, thats really the only way a efi engine will flood unless you crank the car for a while with a weak ingnition system. it could have been flooded but it would take an excess amount of cranking and a very weak ignition system. that would be your fault if thats the case but if you had to crank it for a while, you have other issues. do a full tune up, i bet your whole car feels different.
DnS Performance
  Nissan Forum > Sentra, Pulsar, NX, B14 200SX > B14 95-99 chassis
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Linear Mode Linear Mode
You may post new threads
You may post replies
BB code is On
